주요 콘텐츠로 건너뛰기
Panasonic D-snap SV-AV50 Screen Replacement
필요한 것
  1. Panasonic D-snap SV-AV50 Screen Replacement, Screen: 1 단계, 이미지 1/1
    • Open and rotate the screen, then remove the screw(3.5mm Philips) indicated with a screwdriver.
    • Then, rotate the screen 180 degrees and remove the screw on the opposite side.
  2. Panasonic D-snap SV-AV50 Screen Replacement: 2 단계, 이미지 1/1
    • Remove the screw(2.6mm Philips) indicated on the top of the screen with the screwdriver. Then remove the corresponding screw on the bottom of the screen.
  3. Panasonic D-snap SV-AV50 Screen Replacement: 3 단계, 이미지 1/1
    • Pull the backing away from the screen as shown in the photo.
  4. Panasonic D-snap SV-AV50 Screen Replacement: 4 단계, 이미지 1/1
    • Unplug the black connector between the camera and the screen by pulling down.
    • For increased ease, use tweezers or forceps, as seen in the picture
  5. Panasonic D-snap SV-AV50 Screen Replacement: 5 단계, 이미지 1/1
    • Pull the screen away from the camera the same way that you removed the screen backing.
  6. Panasonic D-snap SV-AV50 Screen Replacement: 6 단계, 이미지 1/1
    • Use the screwdriver to remove the screw(2.46mm Philips) indicated.
  7. Panasonic D-snap SV-AV50 Screen Replacement: 7 단계, 이미지 1/1
    • Pull upwards on the screen border to remove it from the actual screen.
결론
Zoe Hinck
회원 가입일: 04/12/12
29 평판
안내서 4개 작성하였습니다
Cal Poly, Team 6-19, Amido Spring 2012 Cal Poly, Team 6-19, Amido Spring 2012 회원
CPSU-AMIDO-S12S6G19
3 회원들
안내서 12개 작성하였습니다
댓글 한 개
I need the LCD screen, can you helpme?
leon - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 12
전체 시간: 1,072
