주요 콘텐츠로 건너뛰기
Panasonic DECT 6.0 Button Replacement
필요한 것
  1. Panasonic DECT  6.0 Button Replacement, Jammed/Broken Buttons: 1 단계, 이미지 1/3 Panasonic DECT  6.0 Button Replacement, Jammed/Broken Buttons: 1 단계, 이미지 2/3 Panasonic DECT  6.0 Button Replacement, Jammed/Broken Buttons: 1 단계, 이미지 3/3
    • Remove the battery cover by pushing the tab upwards and sliding it off.
    • Pull out the battery/energy source from its slot.
    • Keep all pieces in a safe and orderly manner for ease of reassembly.
  2. Panasonic DECT  6.0 Button Replacement: 2 단계, 이미지 1/3 Panasonic DECT  6.0 Button Replacement: 2 단계, 이미지 2/3 Panasonic DECT  6.0 Button Replacement: 2 단계, 이미지 3/3
    • Unscrew the screws you see on the inside of the casing using an appropriate screwdriver from the JIS Driver Set.
    • Carefully pry each side open with the iFixit Opening tool.
    • Detach the back of the phone case.
  3. Panasonic DECT  6.0 Button Replacement: 3 단계, 이미지 1/3 Panasonic DECT  6.0 Button Replacement: 3 단계, 이미지 2/3 Panasonic DECT  6.0 Button Replacement: 3 단계, 이미지 3/3
    • Unscrew the screws to remove the motherboard using an appropriate screwdriver from the JIS Driver Set.
    • Potential for device damage
  4. Panasonic DECT  6.0 Button Replacement: 4 단계, 이미지 1/3 Panasonic DECT  6.0 Button Replacement: 4 단계, 이미지 2/3 Panasonic DECT  6.0 Button Replacement: 4 단계, 이미지 3/3
    • Carefully pull off the circuitry and cords from the front half of the phone and set them aside.
    • Bring the buttons to the front.
  5. Panasonic DECT  6.0 Button Replacement: 5 단계, 이미지 1/2 Panasonic DECT  6.0 Button Replacement: 5 단계, 이미지 2/2
    • Pull gently to separate the button pad from the phone cover.
    • Identify the broken/jammed button you were having issues with.
    • Replace or return the button to its function.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jacob
회원 가입일: 05/31/16
131 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 10
전체 시간: 536
