주요 콘텐츠로 건너뛰기
Panasonic DMC-FZ70 Motherboard Replacement
필요한 것
  1. Panasonic DMC-FZ70 Motherboard Replacement, Back Panel: 1 단계, 이미지 2개 중 1개 Panasonic DMC-FZ70 Motherboard Replacement, Back Panel: 1 단계, 이미지 2개 중 2개
    • All screws should be removed using a Phillips #0 screwdriver.
    • Using your screwdriver, unscrew the two 5.0 mm Philips screws to the right of the LCD screen.
  2. Panasonic DMC-FZ70 Motherboard Replacement: 2 단계, 이미지 2개 중 1개 Panasonic DMC-FZ70 Motherboard Replacement: 2 단계, 이미지 2개 중 2개
    • Flip the camera over to the left side of the screen and unscrew the 5mm Phillips screw found there.
  3. Panasonic DMC-FZ70 Motherboard Replacement: 3 단계, 이미지 2개 중 1개 Panasonic DMC-FZ70 Motherboard Replacement: 3 단계, 이미지 2개 중 2개
    • Turn the camera upside down and unscrew the three 5mm screws found on the bottom.
  4. Panasonic DMC-FZ70 Motherboard Replacement: 4 단계, 이미지 2개 중 1개 Panasonic DMC-FZ70 Motherboard Replacement: 4 단계, 이미지 2개 중 2개
    • On the top of the camera locate the two rails with a thin sheet of metal on the floor between them.
    • With a metal spudger, lift this sheet and push it out of the rail device to detach it from the camera.
  5. Panasonic DMC-FZ70 Motherboard Replacement: 5 단계, 이미지 1개 중 1개
    • Proceed to remove the four 5mm Phillips screws that you just uncovered.
  6. Panasonic DMC-FZ70 Motherboard Replacement: 6 단계, 이미지 1개 중 1개
    • Slowly pull on both side of the camera, until both halves begin to separate from each other.
    • Do not pull too hard, as both halves are held together with ZIF connector cables.
  7. Panasonic DMC-FZ70 Motherboard Replacement: 7 단계, 이미지 3개 중 1개 Panasonic DMC-FZ70 Motherboard Replacement: 7 단계, 이미지 3개 중 2개 Panasonic DMC-FZ70 Motherboard Replacement: 7 단계, 이미지 3개 중 3개
    • Using a plastic opening tool, carefully flip up the small black levers that attach the ribbon cables to the ZIF connectors on the motherboard.
    • Carefully pull the ribbon cables out of the slot once they have been released.
    • Only the two indicated connectors need to be removed to separate the two halves of the camera.
  8. Panasonic DMC-FZ70 Motherboard Replacement, Motherboard: 8 단계, 이미지 1개 중 1개
    • Using a Torx driver, unscrew the two 5mm Phillipd screws on the motherboard
  9. Panasonic DMC-FZ70 Motherboard Replacement: 9 단계, 이미지 3개 중 1개 Panasonic DMC-FZ70 Motherboard Replacement: 9 단계, 이미지 3개 중 2개 Panasonic DMC-FZ70 Motherboard Replacement: 9 단계, 이미지 3개 중 3개
    • The five ribbon cables shown will need to be removed from the ZIF connectors. Using a plastic opening tool, unlock the cables by lifting the black strip on the rectangular connection socket.
    • Carefully pull each of the ribbon cables out of their sockets.
    • The cable should slide out smoothly- any significant resistance might signal that the locking lever has not yet released the cable.
  10. Panasonic DMC-FZ70 Motherboard Replacement: 10 단계, 이미지 2개 중 1개 Panasonic DMC-FZ70 Motherboard Replacement: 10 단계, 이미지 2개 중 2개
    • Once the screws and the ribbon cables have been removed, lift the mother board from its slot.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Emily Kuzmicky
회원 가입일: 01/24/17
448 평판
안내서 2개를 작성함
Cal Poly, Team 21-3, Maness Winter 2017 Cal Poly, Team 21-3, Maness Winter 2017 회원
CPSU-MANESS-W17S21G3
6 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 13
전체 시간: 2,096
