주요 콘텐츠로 건너뛰기
Panasonic DMP-BD89 Exterior Cover Replacement
필요한 것
  1. Panasonic DMP-BD89 Exterior Cover Replacement, Disk Tray Cover: 1 단계, 이미지 1/2 Panasonic DMP-BD89 Exterior Cover Replacement, Disk Tray Cover: 1 단계, 이미지 2/2
    • First, before powering off, press the eject button to open the tray.
  2. Panasonic DMP-BD89 Exterior Cover Replacement: 2 단계, 이미지 1/3 Panasonic DMP-BD89 Exterior Cover Replacement: 2 단계, 이미지 2/3 Panasonic DMP-BD89 Exterior Cover Replacement: 2 단계, 이미지 3/3
    • Remove the front cover of the tray.
    • Do so by gently pushing it out, away from the player, ensuring the pictured tabs clear the tray.
    • Then slide it vertically up and away.
  3. Panasonic DMP-BD89 Exterior Cover Replacement: 3 단계, 이미지 1/2 Panasonic DMP-BD89 Exterior Cover Replacement: 3 단계, 이미지 2/2
    • Press eject button to close the tray.
    • Make sure to unpower and unplug device before continue work on other fixes.
  4. Panasonic DMP-BD89 Exterior Cover Replacement, Exterior Cover: 4 단계, 이미지 1/2 Panasonic DMP-BD89 Exterior Cover Replacement, Exterior Cover: 4 단계, 이미지 2/2
    • Using a Phillips #1 screwdriver, unscrew the back three screws.
  5. Panasonic DMP-BD89 Exterior Cover Replacement: 5 단계, 이미지 1/1
    • Slide the top panel horizontally to remove it.
  6. Panasonic DMP-BD89 Exterior Cover Replacement: 6 단계, 이미지 1/3 Panasonic DMP-BD89 Exterior Cover Replacement: 6 단계, 이미지 2/3 Panasonic DMP-BD89 Exterior Cover Replacement: 6 단계, 이미지 3/3
    • Locate 6 tabs across the device.
    • 2 are on the bottom, 1 is on the left and right, and 2 are are on the inside.
  7. Panasonic DMP-BD89 Exterior Cover Replacement: 7 단계, 이미지 1/1
    • Pop the 6 markers out.
    • Then take off the cover.
결론
David Sun
회원 가입일: 10/17/17
213 평판
안내서 2개 작성하였습니다
UC Santa Barbara, Team S2-G9, Weedon Fall 2017 UC Santa Barbara, Team S2-G9, Weedon Fall 2017 회원
UCSB-WEEDON-F17S2G9
4 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 10
전체 시간: 252
