주요 콘텐츠로 건너뛰기
Panasonic DMP-BD89 Wifi Board Replacement
필요한 것
  1. Panasonic DMP-BD89 Wifi Board Replacement, Disk Tray Cover: 1 단계, 이미지 2개 중 1개 Panasonic DMP-BD89 Wifi Board Replacement, Disk Tray Cover: 1 단계, 이미지 2개 중 2개
    • First, before powering off, press the eject button to open the tray.
  2. Panasonic DMP-BD89 Wifi Board Replacement: 2 단계, 이미지 3개 중 1개 Panasonic DMP-BD89 Wifi Board Replacement: 2 단계, 이미지 3개 중 2개 Panasonic DMP-BD89 Wifi Board Replacement: 2 단계, 이미지 3개 중 3개
    • Remove the front cover of the tray.
    • Do so by gently pushing it out, away from the player, ensuring the pictured tabs clear the tray.
    • Then slide it vertically up and away.
  3. Panasonic DMP-BD89 Wifi Board Replacement: 3 단계, 이미지 2개 중 1개 Panasonic DMP-BD89 Wifi Board Replacement: 3 단계, 이미지 2개 중 2개
    • Press eject button to close the tray.
    • Make sure to unpower and unplug device before continue work on other fixes.
  4. Panasonic DMP-BD89 Wifi Board Replacement, Exterior Cover: 4 단계, 이미지 2개 중 1개 Panasonic DMP-BD89 Wifi Board Replacement, Exterior Cover: 4 단계, 이미지 2개 중 2개
    • Using a Phillips #1 screwdriver, unscrew the back three screws.
  5. Panasonic DMP-BD89 Wifi Board Replacement: 5 단계, 이미지 1개 중 1개
    • Slide the top panel horizontally to remove it.
  6. Panasonic DMP-BD89 Wifi Board Replacement: 6 단계, 이미지 3개 중 1개 Panasonic DMP-BD89 Wifi Board Replacement: 6 단계, 이미지 3개 중 2개 Panasonic DMP-BD89 Wifi Board Replacement: 6 단계, 이미지 3개 중 3개
    • Locate 6 tabs across the device.
    • 2 are on the bottom, 1 is on the left and right, and 2 are are on the inside.
  7. Panasonic DMP-BD89 Wifi Board Replacement: 7 단계, 이미지 1개 중 1개
    • Pop the 6 markers out.
    • Then take off the cover.
  8. Panasonic DMP-BD89 Wifi Board Replacement, Wifi Board: 8 단계, 이미지 2개 중 1개 Panasonic DMP-BD89 Wifi Board Replacement, Wifi Board: 8 단계, 이미지 2개 중 2개
    • Locate reddish brown cable. Detach from green circuit board by pulling upward.
  9. Panasonic DMP-BD89 Wifi Board Replacement: 9 단계, 이미지 1개 중 1개
    • Using tweezer, compress the white knob holding the wifi module board in place.
  10. Panasonic DMP-BD89 Wifi Board Replacement: 10 단계, 이미지 2개 중 1개 Panasonic DMP-BD89 Wifi Board Replacement: 10 단계, 이미지 2개 중 2개
    • Pull the module board straight up, removing completely. The second photo is how your device should look with the WiFi board removed.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Mohan Saxena
회원 가입일: 10/17/17
133 평판
안내서 1개를 작성함
UC Santa Barbara, Team S2-G9, Weedon Fall 2017 UC Santa Barbara, Team S2-G9, Weedon Fall 2017 회원
UCSB-WEEDON-F17S2G9
4 회원들
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 9
전체 시간: 548
