부품
부품은 필요하지 않습니다.
  1. Eject the disk tray from the DVD player before removing power supply.
    • Eject the disk tray from the DVD player before removing power supply.
  2. Evenly lift upward on the disk tray front cover (not slanted, as pictured). This will allow for easier dissasembly of the player.
    • Evenly lift upward on the disk tray front cover (not slanted, as pictured). This will allow for easier dissasembly of the player.
  3. Remove 3 screws running along back edge of case cover. Remove 2 screws from each side of case cover.
    • Remove 3 screws running along back edge of case cover.
    • Remove 2 screws from each side of case cover.
  4. US$100 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
    상점 둘러보기
  5. Grab edges of cover, pull outward slightly, and pull straight up.
    • Grab edges of cover, pull outward slightly, and pull straight up.
  6. Lift up the 5 tabs securing the front panel to the chassis. There are 3 on the bottom, and 2 on the inside edges of the panel. Panel should then lift off the player. Lift up the 5 tabs securing the front panel to the chassis. There are 3 on the bottom, and 2 on the inside edges of the panel. Panel should then lift off the player.
    • Lift up the 5 tabs securing the front panel to the chassis. There are 3 on the bottom, and 2 on the inside edges of the panel. Panel should then lift off the player.
  7. Locate the 4 screws securing the disk drive assembly. There are two on each side. Use a narrow screwdriver to remove all 4 screws. Remove the blue ribbon wire from its connector. When doing this, be cautious to not damage the connector.
    • Locate the 4 screws securing the disk drive assembly. There are two on each side.
    • Use a narrow screwdriver to remove all 4 screws.
    • Remove the blue ribbon wire from its connector. When doing this, be cautious to not damage the connector.
  8. Lift assembly by the front to pull metal bracket from the power board.
    • Lift assembly by the front to pull metal bracket from the power board.
    • Pull up back end and lift drive out.
  9. With the drive assembly separate from the player, hold as shown and pull the bracket edges away from the disk drive.
    • With the drive assembly separate from the player, hold as shown and pull the bracket edges away from the disk drive.
    • Lift bracket off and reserve for re-assembly.
결론
다른 2명이 해당 안내서를 완성하였습니다.
William
회원 가입일: 2011년 04월 26일
250 평판
안내서 2개 작성하였습니다
Cal Poly, Team 18-20, Garner Spring 2011 Cal Poly, Team 18-20, Garner Spring 2011 회원
CPSU-GARNER-S11S18G20
4 회원들
안내서 11개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 17
전체 시간: 4,572
