주요 콘텐츠로 건너뛰기
Panasonic EB-GD88 Screen Assembly Replacement
필요한 것
  1. Panasonic EB-GD88 Screen Assembly Replacement, Prerequisite Guide for Camera, Screen Assembly: 1 단계, 이미지 1/3 Panasonic EB-GD88 Screen Assembly Replacement, Prerequisite Guide for Camera, Screen Assembly: 1 단계, 이미지 2/3 Panasonic EB-GD88 Screen Assembly Replacement, Prerequisite Guide for Camera, Screen Assembly: 1 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Flip cellphone open.
    • Out of the iFixit tool kit remove the black plastic opening tool, curved tweezers, and 54 bit driver kit.
  2. Panasonic EB-GD88 Screen Assembly Replacement: 2 단계, 이미지 1/1
    • Remove 4 rubber covers on the corners of the cellphone screen by prying them off with flat end of nylon spudger.
    • The rubber covers are glued on, but they should pop off easily.
    • These rubber covers may or may not be present.
  3. Panasonic EB-GD88 Screen Assembly Replacement: 3 단계, 이미지 1/3 Panasonic EB-GD88 Screen Assembly Replacement: 3 단계, 이미지 2/3 Panasonic EB-GD88 Screen Assembly Replacement: 3 단계, 이미지 3/3
    • Using a Y0 tri-wing screwdriver, found in the 54 bit driver kit, remove the two screws above the screen. Twist the screws counterclockwise to remove.
    • These two screws are blueish
    • Using a Y0 tri-wing screwdriver, remove the two screws below the screen. Twist the screws counterclockwise to remove.
    • These two screws are silver and longer than the bluish.
  4. Panasonic EB-GD88 Screen Assembly Replacement: 4 단계, 이미지 1/3 Panasonic EB-GD88 Screen Assembly Replacement: 4 단계, 이미지 2/3 Panasonic EB-GD88 Screen Assembly Replacement: 4 단계, 이미지 3/3
    • Carefully pry front cover of cellphone off with flat end of nylon spudger.
  5. Panasonic EB-GD88 Screen Assembly Replacement: 5 단계, 이미지 1/3 Panasonic EB-GD88 Screen Assembly Replacement: 5 단계, 이미지 2/3 Panasonic EB-GD88 Screen Assembly Replacement: 5 단계, 이미지 3/3
    • Insert nylon spudger or curved tweezers into small gap between the phone's outer gray casing and the inner gray plastic compartment (which holds the green circuit board and screen together). This gap is indicated by red arrows.
    • Use the tools as leverage to pop out inner gray compartment unit (screen, gray plastic, and circuit board) away from the phones outer casing .
    • Place nylon spudger and tweezers in the space between the outer phone casing and the inner gray compartment.
  6. Panasonic EB-GD88 Screen Assembly Replacement, Screen Assembly: 6 단계, 이미지 1/3 Panasonic EB-GD88 Screen Assembly Replacement, Screen Assembly: 6 단계, 이미지 2/3 Panasonic EB-GD88 Screen Assembly Replacement, Screen Assembly: 6 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • At rectangular holes on the sides of screen, use tweezers to remove the screen from the gray plastic component by slipping tweezers under the white tray holding the screen.
    • After the screen should only remain attached to gray component due to the ribbon at the top which connects the screen to the circuit board.
  7. Panasonic EB-GD88 Screen Assembly Replacement: 7 단계, 이미지 1/3 Panasonic EB-GD88 Screen Assembly Replacement: 7 단계, 이미지 2/3 Panasonic EB-GD88 Screen Assembly Replacement: 7 단계, 이미지 3/3
    • On the circuit board, release the two connector ribbons holding the screen to the circuit board. To do this use tweezers to disconnect both the off-white connector piece and the white connector piece.
    • Remove disconnected screen from phone.
  8. Panasonic EB-GD88 Screen Assembly Replacement: 8 단계, 이미지 1/1
    • Attach new screen to circuit board. To reassemble your device, follow these instructions in the reverse order.
결승점
Patricia Taggart
회원 가입일: 02/19/16
1 평판
안내서 3개 작성하였습니다
Ohio State, Team 1-4, Garvin Spring 2016 Ohio State, Team 1-4, Garvin Spring 2016 회원
OSU-GARVIN-S16S1G4
2 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 5
전체 시간: 193
