주요 콘텐츠로 건너뛰기
Panasonic ER-GN30-K Motor Replacement
필요한 것
  1. Panasonic ER-GN30-K Motor Replacement, Motor: 1 단계, 이미지 1개 중 1개
    • Remove the dark transparent cap by gently pulling on it.
  2. Panasonic ER-GN30-K Motor Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the back battery cap from the device by twisting it to the unlock position and pulling.
  3. Panasonic ER-GN30-K Motor Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the black trimmer cap from the top of the device by gently pulling it.
  4. Panasonic ER-GN30-K Motor Replacement: 4 단계, 이미지 1개 중 1개
    • Use a metal spudger to pry apart the silver plastic case.
    • Pull each side of the plastic case off.
  5. Panasonic ER-GN30-K Motor Replacement: 5 단계, 이미지 1개 중 1개
    • Unscrew one 20mm Phillips #00 screw.
  6. Panasonic ER-GN30-K Motor Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the rubber stopper from the top of the motor shaft by gently pulling it off.
  7. Panasonic ER-GN30-K Motor Replacement: 7 단계, 이미지 2개 중 1개 Panasonic ER-GN30-K Motor Replacement: 7 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use a pair of tweezers to remove the plastic cover of the motor shaft by pulling it away from the motor.
  8. Panasonic ER-GN30-K Motor Replacement: 8 단계, 이미지 1개 중 1개
    • Remove the motor from the case by sliding the cover off of it.
결론
다른 6명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Corey Tappan
회원 가입일: 08/27/15
209 평판
안내서 1개를 작성함
USF Tampa, Team 15-3, Blackwell Fall 2015 USF Tampa, Team 15-3, Blackwell Fall 2015 회원
USFT-BLACKWELL-F15S15G3
4 회원들
안내서 10개를 작성함
댓글 2개
My motor working intermittently. Took apart per instruction (very detailed, thank you). Everything loos good on the internals. I think my problem is succumb build up on the negative spring where it makes contact on negative end of battery. I scrapped it a little with tip of knife, working some what better. Need to find small wire brush to get in there and give it a good cleaning. Thank you for your guide :)
Rocko the fixit cat - 답글
Thanks for such a detailed step by step to disassemble. It appears that the motor is not functioning: LD-050FF-2043V motor. But I was not able to find a replacement on the internet. Any suggestions?
David Freedman - 답글
댓글 쓰기
조회 통계:
지난 24시간: 7
지난 7일: 39
지난 30일: 66
전체 시간: 3,946
