소개
You have tried everything to attempt to make your device work again, if nothing has succeeded the motor may need to be replaced. Follow this guide on how to remove the motor.
필요한 것
다른 6명이 해당 안내서를 완성하였습니다.
댓글 2개
My motor working intermittently. Took apart per instruction (very detailed, thank you). Everything loos good on the internals. I think my problem is succumb build up on the negative spring where it makes contact on negative end of battery. I scrapped it a little with tip of knife, working some what better. Need to find small wire brush to get in there and give it a good cleaning. Thank you for your guide :)
Thanks for such a detailed step by step to disassemble. It appears that the motor is not functioning: LD-050FF-2043V motor. But I was not able to find a replacement on the internet. Any suggestions?
