주요 콘텐츠로 건너뛰기
Panasonic ES-RF31 Battery Replacement
필요한 것
  1. Panasonic ES-RF31 Battery Replacement, Battery: 1 단계, 이미지 3개 중 1개 Panasonic ES-RF31 Battery Replacement, Battery: 1 단계, 이미지 3개 중 2개 Panasonic ES-RF31 Battery Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Loose the screw at the bottom part of the razor
  2. Panasonic ES-RF31 Battery Replacement, Removing the Backcover: 2 단계, 이미지 3개 중 1개 Panasonic ES-RF31 Battery Replacement, Removing the Backcover: 2 단계, 이미지 3개 중 2개 Panasonic ES-RF31 Battery Replacement, Removing the Backcover: 2 단계, 이미지 3개 중 3개
    • Slide the cover from top to bottom
  3. Panasonic ES-RF31 Battery Replacement, Removing the Batterycover: 3 단계, 이미지 2개 중 1개 Panasonic ES-RF31 Battery Replacement, Removing the Batterycover: 3 단계, 이미지 2개 중 2개
    • Loosen these eight screws
  4. Panasonic ES-RF31 Battery Replacement, Removing the Battery Cover: 4 단계, 이미지 2개 중 1개 Panasonic ES-RF31 Battery Replacement, Removing the Battery Cover: 4 단계, 이미지 2개 중 2개
    • Insert an opening tool into the gap
    • Gently remove the battery cover
  5. Panasonic ES-RF31 Battery Replacement, Removing the Battery: 5 단계, 이미지 2개 중 1개 Panasonic ES-RF31 Battery Replacement, Removing the Battery: 5 단계, 이미지 2개 중 2개
    Very good, sehr gut
    Frank D - 답글
결론
다른 7명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Daniel
회원 가입일: 07/06/15
961 평판
안내서 2개를 작성함
iFixit EU Team iFixit EU Team 회원
Staff
39 회원들
안내서 1,137개를 작성함
댓글 4개
Thanks Daniel,
I followed your instructions and all went well. One thing to add: after re-assembly of the (loaded) battery my razor would not turn on. At first I thought of a bad contact, but it turned out that the razor needed a few minutes plugged into the power supply. After that it worked fine. I suspect, that the load-control hardware needs the external power to reset itself.
Cheers, Nils
Nils Kay - 답글
Hello Nils!
Thanks for the hint.
Glad to hear that your razor works again!
Greetings
Daniel - 답글
Daniel, thank you very much for instruction.
Unfortunetly, into shaver I found only 1 battery.
Because used 3.7 v element, I prepared 2 x 1.2 v batteries.
Виктор Богачёв - 답글
My razor was the Panasonic ES8103S and the disassembly process was similar. From the pictures above, the battery looks the same. My razor actually had a piece under the slide-off cover that was totally rusted so I will just buy a new one on Amazon for $50. For future reference, I would like to know where you get the replacement battery? There is no model number on the battery and I couldn’t find any info online.
David Paul - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 27
지난 30일: 98
전체 시간: 7,305
