주요 콘텐츠로 건너뛰기
Panasonic GU87 LCD Cover removal Replacement
필요한 것
  1. Panasonic GU87 LCD Cover removal Replacement, LCD Cover removal: 1 단계, 이미지 1개 중 1개
    • Remove the four rubber screw covers from encircled locations.
    • Using a #0 tri wing screwdriver, remove the screws previously hidden below the rubber covers.
    • If you have difficulties finding this screwdriver, it is commonly sold as a Nintendo Gameboy/Wii screwdriver.
  2. Panasonic GU87 LCD Cover removal Replacement: 2 단계, 이미지 1개 중 1개
    • Pry the case open using iPhone tool (as shown), fingernails, small flathead screwdriver, etc.
    • Be mindful of location and magnitude of applied force, so as not to damage the case.
결론
작성자
8다른 기여자 명과 함께
Van
회원 가입일: 06/24/10
7 평판
안내서 8개를 작성함
Cal Poly, Team 2-10, Johann Summer 2010 Cal Poly, Team 2-10, Johann Summer 2010 회원
CPSU-JOHANN-R10S2G10
4 회원들
안내서 20개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 12
전체 시간: 1,693
