주요 콘텐츠로 건너뛰기
Panasonic HC‑VX870 Record Button Replacement
필요한 것
  1. Panasonic HC‑VX870 Record Button Replacement, Side Cover: 1 단계, 이미지 1/3 Panasonic HC‑VX870 Record Button Replacement, Side Cover: 1 단계, 이미지 2/3 Panasonic HC‑VX870 Record Button Replacement, Side Cover: 1 단계, 이미지 3/3
    • Unscrew the J1 screws on the left side of the camcorder.
    • Unscrew the marked screws on the bottom of the camcorder.
    • Unscrew the marked screws on the back of the camcorder.
  2. Panasonic HC‑VX870 Record Button Replacement: 2 단계, 이미지 1/2 Panasonic HC‑VX870 Record Button Replacement: 2 단계, 이미지 2/2
    • Pull off the left side of the camcorder. You may have to use a little force but don't worry about breaking anything in the camcorder.
  3. Panasonic HC‑VX870 Record Button Replacement, Record Button Mechanism: 3 단계, 이미지 1/1
    • Unscrew the indicated screw.
  4. Panasonic HC‑VX870 Record Button Replacement: 4 단계, 이미지 1/1
    • Lift up on the little tab indicated in the picture and push away from the camera in order to remove the record button.
  5. Panasonic HC‑VX870 Record Button Replacement: 5 단계, 이미지 1/3 Panasonic HC‑VX870 Record Button Replacement: 5 단계, 이미지 2/3 Panasonic HC‑VX870 Record Button Replacement: 5 단계, 이미지 3/3
    • Take out the piece that that was held in place by the screw and separate the smaller piece from the larger piece.
결론
Rebecca Maloney
회원 가입일: 01/24/17
501 평판
안내서 5개 작성하였습니다
Cal Poly, Team 13-6, Banghart Winter 2017 Cal Poly, Team 13-6, Banghart Winter 2017 회원
CPSU-BANGHART-W17S13G6
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 8
전체 시간: 432
