주요 콘텐츠로 건너뛰기
Panasonic HC‑VX870 Shoe Adapter Replacement
필요한 것
  1. Panasonic HC‑VX870 Shoe Adapter Replacement, Side Cover: 1 단계, 이미지 1/3 Panasonic HC‑VX870 Shoe Adapter Replacement, Side Cover: 1 단계, 이미지 2/3 Panasonic HC‑VX870 Shoe Adapter Replacement, Side Cover: 1 단계, 이미지 3/3
    • Unscrew the J1 screws on the left side of the camcorder.
    • Unscrew the marked screws on the bottom of the camcorder.
    • Unscrew the marked screws on the back of the camcorder.
  2. Panasonic HC‑VX870 Shoe Adapter Replacement: 2 단계, 이미지 1/2 Panasonic HC‑VX870 Shoe Adapter Replacement: 2 단계, 이미지 2/2
    • Pull off the left side of the camcorder. You may have to use a little force but don't worry about breaking anything in the camcorder.
  3. Panasonic HC‑VX870 Shoe Adapter Replacement, Shoe Adapter: 3 단계, 이미지 1/2 Panasonic HC‑VX870 Shoe Adapter Replacement, Shoe Adapter: 3 단계, 이미지 2/2
    • Unscrew the indicated screw on the right side of the camcorder.
    • Unscrew the indicated screw on the back of the camcorder.
  4. Panasonic HC‑VX870 Shoe Adapter Replacement: 4 단계, 이미지 1/1
    • Unscrew indicated screw on the inside of the left side of the camcorder.
  5. Panasonic HC‑VX870 Shoe Adapter Replacement: 5 단계, 이미지 1/1
    • Remove the top cover of the camcorder by lightly lifting up on the back end of the top and tugging away from the lens (don't be afraid to use force).
  6. Panasonic HC‑VX870 Shoe Adapter Replacement: 6 단계, 이미지 1/2 Panasonic HC‑VX870 Shoe Adapter Replacement: 6 단계, 이미지 2/2
    • Unscrew the indicated screws and remove the piece they hold in place.
  7. Panasonic HC‑VX870 Shoe Adapter Replacement: 7 단계, 이미지 1/2 Panasonic HC‑VX870 Shoe Adapter Replacement: 7 단계, 이미지 2/2
    • Remove the shoe adapter by simply pulling it out of its place.
    • Be sure not to loose the tiny spring that is attached to the shoe adapter as you are removing it.
결론
Rebecca Maloney
회원 가입일: 01/24/17
501 평판
안내서 5개 작성하였습니다
Cal Poly, Team 13-6, Banghart Winter 2017 Cal Poly, Team 13-6, Banghart Winter 2017 회원
CPSU-BANGHART-W17S13G6
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 18
전체 시간: 1,069
