주요 콘텐츠로 건너뛰기
Panasonic HDC-TM15 Record Button Replacement
필요한 것
  1. Panasonic HDC-TM15 Record Button Replacement, Record Button: 1 단계, 이미지 1/1
    • Using the Phillips #00 Screwdriver, unscrew the five .5 mm Phillips #00 screws on the hand-strap side of the camcorder.
  2. Panasonic HDC-TM15 Record Button Replacement: 2 단계, 이미지 1/1
    • Unscrew the six .5 mm Phillips #00 screws on the bottom of the camcorder.
  3. Panasonic HDC-TM15 Record Button Replacement: 3 단계, 이미지 1/3 Panasonic HDC-TM15 Record Button Replacement: 3 단계, 이미지 2/3 Panasonic HDC-TM15 Record Button Replacement: 3 단계, 이미지 3/3
    • Once all eleven screws have been removed, put your hand through the hand-strap and tug on the side cover until it comes off completely.
    • The inside of your camcorder should now be completely exposed, as shown in the photos.
  4. Panasonic HDC-TM15 Record Button Replacement: 4 단계, 이미지 1/2 Panasonic HDC-TM15 Record Button Replacement: 4 단계, 이미지 2/2
    • Unscrew the two 1 mm Phillips #00 black screws in the corners of the green memory card reader.
    • The screws should be surrounded by orange circles.
  5. Panasonic HDC-TM15 Record Button Replacement: 5 단계, 이미지 1/1
    • Unscrew the black 1 mm Phillips #00 black screw in the left center beside the green motherboard.
  6. Panasonic HDC-TM15 Record Button Replacement: 6 단계, 이미지 1/2 Panasonic HDC-TM15 Record Button Replacement: 6 단계, 이미지 2/2
    • Unscrew the 1.2 mm Phillips #00 black screw beneath the motherboard on the bottom of the camcorder.
    • The green motherboard should now be partially detached, as shown in the photo.
  7. Panasonic HDC-TM15 Record Button Replacement: 7 단계, 이미지 1/3 Panasonic HDC-TM15 Record Button Replacement: 7 단계, 이미지 2/3 Panasonic HDC-TM15 Record Button Replacement: 7 단계, 이미지 3/3
    • Remove the long silver plate that secures the record button.
  8. Panasonic HDC-TM15 Record Button Replacement: 8 단계, 이미지 1/1
    • Remove the old record button from beneath the silver plate.
  9. Panasonic HDC-TM15 Record Button Replacement: 9 단계, 이미지 1/2 Panasonic HDC-TM15 Record Button Replacement: 9 단계, 이미지 2/2
    • Place the new Record button into the open slot.
  10. Panasonic HDC-TM15 Record Button Replacement: 10 단계, 이미지 1/2 Panasonic HDC-TM15 Record Button Replacement: 10 단계, 이미지 2/2
    • Slide the silver plate into place beside the new Record button.
    • Ensure that the Battery Eject button is lined up properly.
  11. Panasonic HDC-TM15 Record Button Replacement: 11 단계, 이미지 1/2 Panasonic HDC-TM15 Record Button Replacement: 11 단계, 이미지 2/2
    • Re-screw the green motherboard into place and re-attach the side cover to your camcorder.
    • When the side cover is securely fastened, you have completed the Record Button replacement of your Panasonic HDC-TM15 camcorder.
결론
Emma
회원 가입일: 03/11/15
176 평판
안내서 1개 작성함
Marist, Team 1-4, Laflen Spring 2015 Marist, Team 1-4, Laflen Spring 2015 회원
MARS-LAFLEN-S15S1G4
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 4
전체 시간: 273
