주요 콘텐츠로 건너뛰기
Panasonic HDC-TM15 Side Cover Replacement
필요한 것
  1. Panasonic HDC-TM15 Side Cover Replacement, Side Cover: 1 단계, 이미지 1/1
    • Using the Phillips #00 Screwdriver, unscrew the five .5 mm Phillips #00 screws on the hand-strap side of the camcorder.
  2. Panasonic HDC-TM15 Side Cover Replacement: 2 단계, 이미지 1/1
    • Next, unscrew the six .5 mm Phillips #00 screws on the bottom of the camcorder.
  3. Panasonic HDC-TM15 Side Cover Replacement: 3 단계, 이미지 1/3 Panasonic HDC-TM15 Side Cover Replacement: 3 단계, 이미지 2/3 Panasonic HDC-TM15 Side Cover Replacement: 3 단계, 이미지 3/3
    • By putting your hand through the hand-strap, tug on the side cover until it comes off completely.
    • Once the old cover is completely detached, set it aside.
    • The inside of your camcorder should now be completely exposed, as seen in the photos.
  4. Panasonic HDC-TM15 Side Cover Replacement: 4 단계, 이미지 1/2 Panasonic HDC-TM15 Side Cover Replacement: 4 단계, 이미지 2/2
    • Line up the new side cover in the exact same place, ensuring that the screw holes match.
    • Re-screw the side cover into place.
  5. Panasonic HDC-TM15 Side Cover Replacement: 5 단계, 이미지 1/1
    • Gently tug on the hand-strap to ensure that the screws are tight and the side cover is secure.
    • When the side cover is securely fastened, you have completed the side cover replacement of your Panasonic HDC-TM15 camcorder.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Tricia Fallo
회원 가입일: 03/11/15
210 평판
안내서 2개 작성하였습니다
Marist, Team 1-4, Laflen Spring 2015 Marist, Team 1-4, Laflen Spring 2015 회원
MARS-LAFLEN-S15S1G4
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 8
전체 시간: 326
