주요 콘텐츠로 건너뛰기
Panasonic KX-E603 Fuse Replacement
필요한 것
  1. Panasonic KX-E603 Fuse Replacement, Case: 1 단계, 이미지 1/2 Panasonic KX-E603 Fuse Replacement, Case: 1 단계, 이미지 2/2
    • Flip the typewriter to expose the bottom body panel.
    • Be careful to not damage the top surface of the typewriter when you rest it upside-down.
  2. Panasonic KX-E603 Fuse Replacement: 2 단계, 이미지 1/1
    • Remove the three 19 mm screws located in the recessed holes on the edge of the black underside panel using a Phillips #2 screwdriver.
  3. Panasonic KX-E603 Fuse Replacement: 3 단계, 이미지 1/1
    • Flip the typewriter back to its original orientation, then rotate it so that the rear is facing towards you.
    • Remove the three 19 mm screws near the bottom of the tan body panel using a Phillips #2 screwdriver.
  4. Panasonic KX-E603 Fuse Replacement: 4 단계, 이미지 1/2 Panasonic KX-E603 Fuse Replacement: 4 단계, 이미지 2/2
    • Open the typewriter lid and push the carriage away to expose the two screws holding the case to the chassis.
    • Remove the two 19 mm screws using a Phillips #2 screwdriver.
  5. Panasonic KX-E603 Fuse Replacement: 5 단계, 이미지 1/2 Panasonic KX-E603 Fuse Replacement: 5 단계, 이미지 2/2
    • Flip the plastic lever on the right side of the roller wheel to disengage the paper lock.
  6. Panasonic KX-E603 Fuse Replacement: 6 단계, 이미지 1/3 Panasonic KX-E603 Fuse Replacement: 6 단계, 이미지 2/3 Panasonic KX-E603 Fuse Replacement: 6 단계, 이미지 3/3
    • Remove the roller wheel adjustment knobs by pulling firmly outward.
    • Both black knobs must be removed in this step.
  7. Panasonic KX-E603 Fuse Replacement: 7 단계, 이미지 1/2 Panasonic KX-E603 Fuse Replacement: 7 단계, 이미지 2/2
    • Unlock the roller wheel by simultaneously pressing down on the two spring levers on the left and right of the roller ends.
  8. Panasonic KX-E603 Fuse Replacement: 8 단계, 이미지 1/2 Panasonic KX-E603 Fuse Replacement: 8 단계, 이미지 2/2
    • While both spring levers are depressed, lift up with both hands to remove the roller wheel.
  9. Panasonic KX-E603 Fuse Replacement: 9 단계, 이미지 1/3 Panasonic KX-E603 Fuse Replacement: 9 단계, 이미지 2/3 Panasonic KX-E603 Fuse Replacement: 9 단계, 이미지 3/3
    • Flip the top down. Then, with both hands, lift straight up on the tan case to remove it from the chassis.
  10. Panasonic KX-E603 Fuse Replacement, Fuse: 10 단계, 이미지 1/1
    • The capacitors can be a shock hazard, avoid touching them.
    • The fuse can be found very close to two large, blue capacitors near the rear of the typewriter.
  11. Panasonic KX-E603 Fuse Replacement: 11 단계, 이미지 1/1
    • The fuse body is made from glass; be careful not to use too much force or it could break.
    • Firmly grasp the fuse between your fingers and pull upwards to remove it from its mount.
    • If the fuse is difficult to grasp with your hands, a spudger may be used instead.
결론
To reassemble your device, use the new fuse and follow these instructions in reverse order.
Lindsay Stratis
회원 가입일: 04/08/15
491 평판
안내서 4개 작성하였습니다
Cal Poly, Team 17-1, Forte Spring 2015 Cal Poly, Team 17-1, Forte Spring 2015 회원
CPSU-FORTE-S15S17G1
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 8
전체 시간: 446
