주요 콘텐츠로 건너뛰기
Panasonic KX-E603 Printwheel Replacement
  1. Panasonic KX-E603 Printwheel Replacement, Ink Cartridge: 1 단계, 이미지 1/2 Panasonic KX-E603 Printwheel Replacement, Ink Cartridge: 1 단계, 이미지 2/2
    • Open the lid of the typewriter.
  2. Panasonic KX-E603 Printwheel Replacement: 2 단계, 이미지 1/2 Panasonic KX-E603 Printwheel Replacement: 2 단계, 이미지 2/2
    • To release the green locking lever, pull it towards you.
  3. Panasonic KX-E603 Printwheel Replacement: 3 단계, 이미지 1/2 Panasonic KX-E603 Printwheel Replacement: 3 단계, 이미지 2/2
    • Gently lift to remove the old ink cartridge.
  4. Panasonic KX-E603 Printwheel Replacement, Printwheel: 4 단계, 이미지 1/2 Panasonic KX-E603 Printwheel Replacement, Printwheel: 4 단계, 이미지 2/2
    • Firmly grasp either one, or both of the plastic printwheel ends protruding from the carriage as seen.
    • Gently lift the printwheel while slightly pushing forward to remove the printwheel from its housing.
결론
To reassemble your device, follow these steps in reverse using your new printwheel.
Lindsay Stratis
회원 가입일: 04/08/15
491 평판
안내서 4개 작성하였습니다
Cal Poly, Team 17-1, Forte Spring 2015 Cal Poly, Team 17-1, Forte Spring 2015 회원
CPSU-FORTE-S15S17G1
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 4
전체 시간: 416
