주요 콘텐츠로 건너뛰기
Panasonic KX-E603 Stepper Motor Replacement
필요한 것
  1. Panasonic KX-E603 Stepper Motor Replacement, Case: 1 단계, 이미지 1/2 Panasonic KX-E603 Stepper Motor Replacement, Case: 1 단계, 이미지 2/2
    • Flip the typewriter to expose the bottom body panel.
    • Be careful to not damage the top surface of the typewriter when you rest it upside-down.
  2. Panasonic KX-E603 Stepper Motor Replacement: 2 단계, 이미지 1/1
    • Remove the three 19 mm screws located in the recessed holes on the edge of the black underside panel using a Phillips #2 screwdriver.
  3. Panasonic KX-E603 Stepper Motor Replacement: 3 단계, 이미지 1/1
    • Flip the typewriter back to its original orientation, then rotate it so that the rear is facing towards you.
    • Remove the three 19 mm screws near the bottom of the tan body panel using a Phillips #2 screwdriver.
  4. Panasonic KX-E603 Stepper Motor Replacement: 4 단계, 이미지 1/2 Panasonic KX-E603 Stepper Motor Replacement: 4 단계, 이미지 2/2
    • Open the typewriter lid and push the carriage away to expose the two screws holding the case to the chassis.
    • Remove the two 19 mm screws using a Phillips #2 screwdriver.
  5. Panasonic KX-E603 Stepper Motor Replacement: 5 단계, 이미지 1/2 Panasonic KX-E603 Stepper Motor Replacement: 5 단계, 이미지 2/2
    • Flip the plastic lever on the right side of the roller wheel to disengage the paper lock.
  6. Panasonic KX-E603 Stepper Motor Replacement: 6 단계, 이미지 1/3 Panasonic KX-E603 Stepper Motor Replacement: 6 단계, 이미지 2/3 Panasonic KX-E603 Stepper Motor Replacement: 6 단계, 이미지 3/3
    • Remove the roller wheel adjustment knobs by pulling firmly outward.
    • Both black knobs must be removed in this step.
  7. Panasonic KX-E603 Stepper Motor Replacement: 7 단계, 이미지 1/2 Panasonic KX-E603 Stepper Motor Replacement: 7 단계, 이미지 2/2
    • Unlock the roller wheel by simultaneously pressing down on the two spring levers on the left and right of the roller ends.
  8. Panasonic KX-E603 Stepper Motor Replacement: 8 단계, 이미지 1/2 Panasonic KX-E603 Stepper Motor Replacement: 8 단계, 이미지 2/2
    • While both spring levers are depressed, lift up with both hands to remove the roller wheel.
  9. Panasonic KX-E603 Stepper Motor Replacement: 9 단계, 이미지 1/3 Panasonic KX-E603 Stepper Motor Replacement: 9 단계, 이미지 2/3 Panasonic KX-E603 Stepper Motor Replacement: 9 단계, 이미지 3/3
    • Flip the top down. Then, with both hands, lift straight up on the tan case to remove it from the chassis.
  10. Panasonic KX-E603 Stepper Motor Replacement, Stepper Motor: 10 단계, 이미지 1/2 Panasonic KX-E603 Stepper Motor Replacement, Stepper Motor: 10 단계, 이미지 2/2
    • Do not remove the screws fully from the stepper motor. Just unscrew them enough to allow the stepper motor to come loose. Removing them all the way can cause damage to the motor.
    • The stepper motor is located on the left when looking from the rear of the typewriter. Rotate the typewriter so that the stepper motor is facing you.
    • While loosening the screws, use your finger to brace the corresponding nuts found on the opposite side of the stepper motor mounting bracket.
    • Using a P1 screwdriver, unscrew the top right and bottom right integrated #3 screws from the back of the stepper motor.
  11. Panasonic KX-E603 Stepper Motor Replacement: 11 단계, 이미지 1/1
    • Remove the stepper motor by pulling it straight out.
결론
To reassemble your device, follow these instructions in reverse order using a working stepper motor.
Lindsay Stratis
회원 가입일: 04/08/15
491 평판
안내서 4개 작성하였습니다
Cal Poly, Team 17-1, Forte Spring 2015 Cal Poly, Team 17-1, Forte Spring 2015 회원
CPSU-FORTE-S15S17G1
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 8
전체 시간: 496
