주요 콘텐츠로 건너뛰기
Panasonic KX-TG6021M Front Speaker Replacement
필요한 것
  1. Panasonic KX-TG6021M Front Speaker Replacement, Battery: 1 단계, 이미지 1/2 Panasonic KX-TG6021M Front Speaker Replacement, Battery: 1 단계, 이미지 2/2
    • Slide the back cover down towards the bottom of the phone to remove.
  2. Panasonic KX-TG6021M Front Speaker Replacement: 2 단계, 이미지 1/3 Panasonic KX-TG6021M Front Speaker Replacement: 2 단계, 이미지 2/3 Panasonic KX-TG6021M Front Speaker Replacement: 2 단계, 이미지 3/3
    • Pull the top of the battery towards you to remove it from the phone.
  3. Panasonic KX-TG6021M Front Speaker Replacement, Front Panel: 3 단계, 이미지 1/2 Panasonic KX-TG6021M Front Speaker Replacement, Front Panel: 3 단계, 이미지 2/2
    • Unscrew the two screws located at the bottom of the phone.
    • Use a PH00 Phillips head to remove the 9 mm screws.
  4. Panasonic KX-TG6021M Front Speaker Replacement: 4 단계, 이미지 1/3 Panasonic KX-TG6021M Front Speaker Replacement: 4 단계, 이미지 2/3 Panasonic KX-TG6021M Front Speaker Replacement: 4 단계, 이미지 3/3
    • Separate the back cover from the front cover by using a wedge.
    • Remove the back cover from the front cover by pulling them apart.
  5. Panasonic KX-TG6021M Front Speaker Replacement: 5 단계, 이미지 1/1
    • Remove three screws on the motherboard.
    • Pull the phone face off of the motherboard.
  6. Panasonic KX-TG6021M Front Speaker Replacement, Front Speaker: 6 단계, 이미지 1/1
    • Remove the front speaker housing by detaching it from the circuit board.
  7. Panasonic KX-TG6021M Front Speaker Replacement: 7 단계, 이미지 1/1
    • Pop out the front speaker from the housing.
  8. Panasonic KX-TG6021M Front Speaker Replacement: 8 단계, 이미지 1/1
    • Desolder the two connections and remove the wires from the circuit board.
결론
paul scruggs
회원 가입일: 10/24/16
177 평판
안내서 1개 작성함
IUPUI, Team 3-1, Baechle Fall 2016 IUPUI, Team 3-1, Baechle Fall 2016 회원
IUPUI-BAECHLE-F16S3G1
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 8
전체 시간: 214
