주요 콘텐츠로 건너뛰기
Panasonic KX-TGA600M Keypad Replacement
필요한 것
  1. Panasonic KX-TGA600M Keypad Replacement, Battery: 1 단계, 이미지 1/2 Panasonic KX-TGA600M Keypad Replacement, Battery: 1 단계, 이미지 2/2
    • On the back of the phone, remove battery cover.
    • Push down on the marked indentation and pull downwards.
  2. Panasonic KX-TGA600M Keypad Replacement: 2 단계, 이미지 1/1
    • Pull out to remove the battery.
  3. Panasonic KX-TGA600M Keypad Replacement, Keypad: 3 단계, 이미지 1/1
    • Once battery is removed, use the Phillips #00 screwdriver to remove the two silver screws at the bottom left and right corners on the back of the phone.
  4. Panasonic KX-TGA600M Keypad Replacement: 4 단계, 이미지 1/3 Panasonic KX-TGA600M Keypad Replacement: 4 단계, 이미지 2/3 Panasonic KX-TGA600M Keypad Replacement: 4 단계, 이미지 3/3
    • Pull the phone apart. The plastic opening tool may be needed.
    • The clear light piece will fall out, so make sure you place it next to the screws.
  5. Panasonic KX-TGA600M Keypad Replacement: 5 단계, 이미지 1/3 Panasonic KX-TGA600M Keypad Replacement: 5 단계, 이미지 2/3 Panasonic KX-TGA600M Keypad Replacement: 5 단계, 이미지 3/3
    • Use the Phillips #00 screwdriver to remove the three screws holding the circuit-board in place.
    • The screws are located in the top right corner, bottom left corner, and bottom right corner.
  6. Panasonic KX-TGA600M Keypad Replacement: 6 단계, 이미지 1/1
    • Once the screws are out, remove the charging contacts beneath the two bottom corner screws.
  7. Panasonic KX-TGA600M Keypad Replacement: 7 단계, 이미지 1/1
    • Remove the circuit board.
  8. Panasonic KX-TGA600M Keypad Replacement: 8 단계, 이미지 1/1
    • Pull back the black silicone keypad.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Lauren Bowman
회원 가입일: 01/31/17
158 평판
안내서 1개 작성함
댓글 한 개
Incomplete explanation with what materials to clean
asalmoom - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 11
전체 시간: 552
