주요 콘텐츠로 건너뛰기
Panasonic KX-TGE233 Base Front Panel Assembly Replacement
필요한 것
  1. Panasonic KX-TGE233 Base Front Panel Assembly Replacement, Base Front Panel Assembly: 1 단계, 이미지 1/1
    • To fix this component, we'll need to work with the main docking station. This is the one with the answering machine and the TEL line.
  2. Panasonic KX-TGE233 Base Front Panel Assembly Replacement: 2 단계, 이미지 1/1
    • To start, we'll need to work with objects on the bottom of the device, so begin by flipping the device over.
  3. Panasonic KX-TGE233 Base Front Panel Assembly Replacement: 3 단계, 이미지 1/1
    • To open the main docking station, you'll need to remove four 11 mm Philips #0 screws.
  4. Panasonic KX-TGE233 Base Front Panel Assembly Replacement: 4 단계, 이미지 1/1
    • With the screws removed, you can use a spudger to aid in removing the back from the device.
    • Levering the back by the spudger may break the tool!
  5. Panasonic KX-TGE233 Base Front Panel Assembly Replacement: 5 단계, 이미지 1/1
    • With the back removed, we now have direct access to all other components in the main docking station.
결론
Jesse Satterwhite
회원 가입일: 02/11/16
682 평판
안내서 5개 작성하였습니다
IUPUI, Team 2-2, Baechle Spring 2016 IUPUI, Team 2-2, Baechle Spring 2016 회원
IUPUI-BAECHLE-S16S2G2
5 회원들
안내서 15개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 10
30일 전: 12
전체 시간: 303
