소개
Steps for removing the back half of the case and replacing it with a new one.
필요한 것
Slide the lock switch to the right so that it is in the unlocked position.
Use your finger to slide the battery hatch in the direction of the downward arrow so that the hatch is open.
Using the Phillips #00 screwdriver, remove the two 2.8 mm Phillips screws located under the hatch.
Place the camera on the surface with the front side facing down. Use the spudger to open the film strip locking mechanism and remove strip.
Hold down on the camera's metal casing with one hand. Using your other hand, remove the back case from the rest of the camera so the film strip separates.
다른 한 분이 해당 안내서를 완성하였습니다.
