주요 콘텐츠로 건너뛰기
소개
Steps for removing the back half of the case and replacing it with a new one.
부품
지정된 부품이 없습니다.
  1. Slide the lock into the unlocked position to the right.
    • Slide the lock into the unlocked position to the right.
    • Use your finger to slide battery hatch towards the arrow sign.
    • Both battery and memory card should now be visible.
  2. Open battery hatch and the black cover to expose the battery compartment.
    • Open battery hatch and the black cover to expose the battery compartment.
    • The camera used to create these repair guides did not have a battery and memory card.
    • Pull the battery out and replace with a new one.
    • When putting the battery back in, make sure it is in the same orientation as before.
    • Close the battery compartment and make sure the lock is in the locked position.
  3. Remove the two 2.8 mm Phillips screws.
    • Remove the two 2.8 mm Phillips screws.
  4. Use a Phillips screwdriver to remove the three 2.8 mm screws on the bottom of the camera.
    • Use a Phillips screwdriver to remove the three 2.8 mm screws on the bottom of the camera.
  5. Remove the two 2.8 mm Phillips screws on the side of the camera as shown in picture.
    • Remove the two 2.8 mm Phillips screws on the side of the camera as shown in picture.
  6. Use a spudger to  pry open the case from all sides. Use a spudger to  pry open the case from all sides.
    • Use a spudger to pry open the case from all sides.
  7. Beware of the ribbon cable that is still attached when opening. Use your fingers to  carefully pry off the back casing from the camera assembly.
    • Beware of the ribbon cable that is still attached when opening.
    • Use your fingers to carefully pry off the back casing from the camera assembly.
  8. Lay the camera on its front side. Use the spudger to open the film strip locking mechanism and remove strip.
    • Lay the camera on its front side. Use the spudger to open the film strip locking mechanism and remove strip.
    • Hold down on the camera's metal casing with one hand. Use your other hand to completely lift the back case off the rest of the camera, making sure the film strip separates.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Alex Penman
회원 가입일: 2011년 01월 28일
463 평판
안내서 4개 작성하였습니다
Cal Poly, Team 7-35, Regan Winter 2011 Cal Poly, Team 7-35, Regan Winter 2011 회원
CPSU-REGAN-W11S7G35
4 회원들
안내서 10개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 785
