주요 콘텐츠로 건너뛰기
Panasonic Lumix DMC-F7 Battery Replacement
  1. Panasonic Lumix DMC-F7 Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Slide the lock switch to the right so that it is in the unlocked position.
    • Use your finger to slide the battery hatch in the direction of the downward arrow so that the hatch is open.
    • Both battery and memory card should now be visible.
  2. Panasonic Lumix DMC-F7 Battery Replacement: 2 단계, 이미지 1/1
    • Open the battery hatch and then the black cover to expose the battery compartment.
    • The camera used to create these repair guides did not have a battery and memory card.
    • Remove the battery.
    • When installing the new battery, ensure it is in the same orientation as before.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Hormoz Tarevern
회원 가입일: 01/05/11
170 평판
안내서 1개 작성함
Cal Poly, Team 7-35, Regan Winter 2011 Cal Poly, Team 7-35, Regan Winter 2011 회원
CPSU-REGAN-W11S7G35
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 11
전체 시간: 2,299
