소개
Fixing the lens apparatus on your camera.
필요한 것
Slide the lock switch to the right so that it is in the unlocked position.
Use your finger to slide the battery hatch in the direction of the downward arrow so that the hatch is open.
Using the Phillips #00 screwdriver, remove the two 2.8 mm Phillips screws located under the hatch.
Place the camera on the surface with the front side facing down. Use the spudger to open the film strip locking mechanism and remove strip.
Hold down on the camera's metal casing with one hand. Using your other hand, remove the back case from the rest of the camera so the film strip separates.
Remove the last two 2.8 mm Phillips screws from the bottom of the camera.
Using the Spudger tool, pry the front case away from the camera's components.
Use your fingers to carefully pull the back case from the front case.
Cut the black and red wires connecting front case to the body of the camera.
Separate the front of the case from the camera.
To reinstall the front case, solder the wires of the new case to the components of the camera.
Check the "V" shaped spring to see if it is connected to the body of the camera.
다른 한 분이 해당 안내서를 완성하였습니다.
