주요 콘텐츠로 건너뛰기
이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
Panasonic Lumix DMC-F7 Fixing the Lens Apparatus Replacement
필요한 것
  1. Panasonic Lumix DMC-F7 Fixing the Lens Apparatus Replacement, Battery: 1 단계, 이미지 1/1
    • Slide the lock switch to the right so that it is in the unlocked position.
    • Use your finger to slide the battery hatch in the direction of the downward arrow so that the hatch is open.
    • Both battery and memory card should now be visible.
  2. Panasonic Lumix DMC-F7 Fixing the Lens Apparatus Replacement: 2 단계, 이미지 1/1
    • Open the battery hatch and then the black cover to expose the battery compartment.
    • The camera used to create these repair guides did not have a battery and memory card.
    • Remove the battery.
    • When installing the new battery, ensure it is in the same orientation as before.
  3. Panasonic Lumix DMC-F7 Fixing the Lens Apparatus Replacement, Back Case: 3 단계, 이미지 1/1
    • Using the Phillips #00 screwdriver, remove the two 2.8 mm screws located under the hatch.
  4. Panasonic Lumix DMC-F7 Fixing the Lens Apparatus Replacement: 4 단계, 이미지 1/1
    • Use the Phillips #00 screwdriver to remove the three 2.8 mm screws on the bottom of the camera.
  5. Panasonic Lumix DMC-F7 Fixing the Lens Apparatus Replacement: 5 단계, 이미지 1/1
    • Use the Phillips #00 screwdriver to remove the two 2.8 mm screws on the side of the camera.
  6. Panasonic Lumix DMC-F7 Fixing the Lens Apparatus Replacement: 6 단계, 이미지 1/2 Panasonic Lumix DMC-F7 Fixing the Lens Apparatus Replacement: 6 단계, 이미지 2/2
    • Use a spudger to pry open the case at all sides.
  7. Panasonic Lumix DMC-F7 Fixing the Lens Apparatus Replacement: 7 단계, 이미지 1/2 Panasonic Lumix DMC-F7 Fixing the Lens Apparatus Replacement: 7 단계, 이미지 2/2
    • Be careful not to damage the ribbon cable when opening. Ensure it is still attached.
    • Use your fingers to carefully remove the back casing from the front of the camera.
  8. Panasonic Lumix DMC-F7 Fixing the Lens Apparatus Replacement: 8 단계, 이미지 1/1
    • Place the camera on a flat surface with the front side facing down.
    • Use the spudger to flip up the retaining flap and slide the ribbon cable out of the connector.
    • Hold down on the camera's metal casing with one hand. Using your other hand, remove the back case from the rest of the camera.
  9. Panasonic Lumix DMC-F7 Fixing the Lens Apparatus Replacement, Front Case: 9 단계, 이미지 1/1
    • Remove the last two 2.8 mm Phillips #00 screws from the bottom of the camera.
  10. Panasonic Lumix DMC-F7 Fixing the Lens Apparatus Replacement: 10 단계, 이미지 1/3 Panasonic Lumix DMC-F7 Fixing the Lens Apparatus Replacement: 10 단계, 이미지 2/3 Panasonic Lumix DMC-F7 Fixing the Lens Apparatus Replacement: 10 단계, 이미지 3/3
    • Using the spudger, pry the front case away from the camera's components.
    • Use your fingers to carefully pull the back case from the front case.
    • Cut the black and red wires connecting front case to the body of the camera.
    • Be careful to ensure that internal materials won't be caught.
    • Separate the front of the case from the camera.
    • To reinstall the front case, solder the wires of the new case to the components of the camera.
  11. Panasonic Lumix DMC-F7 Fixing the Lens Apparatus Replacement, Fixing the Lens Apparatus: 11 단계, 이미지 1/1
    • Check the "V" shaped spring to see if it is connected.
  12. Panasonic Lumix DMC-F7 Fixing the Lens Apparatus Replacement: 12 단계, 이미지 1/1
    • Manually move the lens apparatus from the inside to shown position.
    • Check to see if the spring is aligned correctly and the lens opens.
    • If not, you will need to take out the spring and place it into the proper position, or get a new spring all together.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Alex Penman
회원 가입일: 01/28/11
463 평판
안내서 4개 작성하였습니다
Cal Poly, Team 7-35, Regan Winter 2011 Cal Poly, Team 7-35, Regan Winter 2011 회원
CPSU-REGAN-W11S7G35
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 1,404
