소개
Fixing the lens apparatus on your camera.
필요한 것
Slide the lock switch to the right so that it is in the unlocked position.
Use your finger to slide the battery hatch in the direction of the downward arrow so that the hatch is open.
Using the Phillips #00 screwdriver, remove the two 2.8 mm screws located under the hatch.
Check the "V" shaped spring to see if it is connected to the body of the camera.
다른 한 분이 해당 안내서를 완성하였습니다.
