주요 콘텐츠로 건너뛰기
Panasonic Lumix DMC-F7 Replacing LCD Screen Replacement
필요한 것
  1. Panasonic Lumix DMC-F7 Replacing LCD Screen Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Slide the lock switch to the right so that it is in the unlocked position.
    • Use your finger to slide the battery hatch in the direction of the downward arrow so that the hatch is open.
    • Both battery and memory card should now be visible.
  2. Panasonic Lumix DMC-F7 Replacing LCD Screen Replacement: 2 단계, 이미지 1개 중 1개
    • Open the battery hatch and then the black cover to expose the battery compartment.
    • The camera used to create these repair guides did not have a battery and memory card.
    • Remove the battery.
    • When installing the new battery, ensure it is in the same orientation as before.
  3. Panasonic Lumix DMC-F7 Replacing LCD Screen Replacement, Back Case: 3 단계, 이미지 1개 중 1개
    • Using the Phillips #00 screwdriver, remove the two 2.8 mm screws located under the hatch.
  4. Panasonic Lumix DMC-F7 Replacing LCD Screen Replacement: 4 단계, 이미지 1개 중 1개
    • Use the Phillips #00 screwdriver to remove the three 2.8 mm screws on the bottom of the camera.
  5. Panasonic Lumix DMC-F7 Replacing LCD Screen Replacement: 5 단계, 이미지 1개 중 1개
    • Use the Phillips #00 screwdriver to remove the two 2.8 mm screws on the side of the camera.
  6. Panasonic Lumix DMC-F7 Replacing LCD Screen Replacement: 6 단계, 이미지 2개 중 1개 Panasonic Lumix DMC-F7 Replacing LCD Screen Replacement: 6 단계, 이미지 2개 중 2개
    • Use a spudger to pry open the case at all sides.
  7. Panasonic Lumix DMC-F7 Replacing LCD Screen Replacement: 7 단계, 이미지 2개 중 1개 Panasonic Lumix DMC-F7 Replacing LCD Screen Replacement: 7 단계, 이미지 2개 중 2개
    • Be careful not to damage the ribbon cable when opening. Ensure it is still attached.
    • Use your fingers to carefully remove the back casing from the front of the camera.
  8. Panasonic Lumix DMC-F7 Replacing LCD Screen Replacement: 8 단계, 이미지 1개 중 1개
    • Place the camera on a flat surface with the front side facing down.
    • Use the spudger to flip up the retaining flap and slide the ribbon cable out of the connector.
    • Hold down on the camera's metal casing with one hand. Using your other hand, remove the back case from the rest of the camera.
  9. Panasonic Lumix DMC-F7 Replacing LCD Screen Replacement, Replacing LCD Screen: 9 단계, 이미지 2개 중 1개 Panasonic Lumix DMC-F7 Replacing LCD Screen Replacement, Replacing LCD Screen: 9 단계, 이미지 2개 중 2개
    • Use a spudger to lift the screen ZIF connector tab.
    • Use the back of the spudger to push the ribbon cable free.
  10. Panasonic Lumix DMC-F7 Replacing LCD Screen Replacement: 10 단계, 이미지 3개 중 1개 Panasonic Lumix DMC-F7 Replacing LCD Screen Replacement: 10 단계, 이미지 3개 중 2개 Panasonic Lumix DMC-F7 Replacing LCD Screen Replacement: 10 단계, 이미지 3개 중 3개
    • Use the screwdriver to remove the four 2.4 mm Phillips screws.
    • Lift up the LCD screen from the front case.
    • Potential for device damage: The wire is still connected to the board in the other side.
  11. Panasonic Lumix DMC-F7 Replacing LCD Screen Replacement: 11 단계, 이미지 1개 중 1개
    • Remove the LCD screen from its case.
  12. Panasonic Lumix DMC-F7 Replacing LCD Screen Replacement: 12 단계, 이미지 1개 중 1개
    • Locate the wire connecting the LCD screen to the motherboard.
    • Use the soldering iron to desolder the wire.
    • Use the soldering iron to solder wires from new LCD screen to the circuit board.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
11다른 기여자 명과 함께
Alex Penman
회원 가입일: 01/28/11
463 평판
안내서 4개를 작성함
Cal Poly, Team 7-35, Regan Winter 2011 Cal Poly, Team 7-35, Regan Winter 2011 회원
CPSU-REGAN-W11S7G35
4 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 5
전체 시간: 3,222
