주요 콘텐츠로 건너뛰기
Panasonic Lumix DMC-FH20 LCD Screen Replacement
필요한 것
  1. Panasonic Lumix DMC-FH20 LCD Screen Replacement, LCD Screen: 1 단계, 이미지 1/3 Panasonic Lumix DMC-FH20 LCD Screen Replacement, LCD Screen: 1 단계, 이미지 2/3 Panasonic Lumix DMC-FH20 LCD Screen Replacement, LCD Screen: 1 단계, 이미지 3/3
    • Remove all screws (Phillips #000 head) from the sides and bottom of the camera.
  2. Panasonic Lumix DMC-FH20 LCD Screen Replacement: 2 단계, 이미지 1/1
    • Remove the back panel. This might require some extra force. If you still can't get the panel off, try to use a plastic opening tool.
  3. Panasonic Lumix DMC-FH20 LCD Screen Replacement: 3 단계, 이미지 1/2 Panasonic Lumix DMC-FH20 LCD Screen Replacement: 3 단계, 이미지 2/2
    • Remove the circuit board. You should be able to do this with your fingers. Just grab it and pull upwards. If it does not come, use a plastic opening tool to help.
  4. Panasonic Lumix DMC-FH20 LCD Screen Replacement: 4 단계, 이미지 1/2 Panasonic Lumix DMC-FH20 LCD Screen Replacement: 4 단계, 이미지 2/2
    • Remove the white plastic cover. This may take some extra force. You will want to try to remove from the bottom side first and peel up.
    • Then, where the silver switch is located, it will slide directly out at the top.
  5. Panasonic Lumix DMC-FH20 LCD Screen Replacement: 5 단계, 이미지 1/1
    • Unscrew one screw (Phillips #000 head).
  6. Panasonic Lumix DMC-FH20 LCD Screen Replacement: 6 단계, 이미지 1/3 Panasonic Lumix DMC-FH20 LCD Screen Replacement: 6 단계, 이미지 2/3 Panasonic Lumix DMC-FH20 LCD Screen Replacement: 6 단계, 이미지 3/3
    • You will want to use a plastic opening tool to complete this step. Pop the thin black piece of plastic upwards with the opening tool to unlock the plastic film ribbon.
    • Once unlocked, you will be able to pull the ribbon out and remove the screen completely.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Arianna Boushell
회원 가입일: 01/24/17
626 평판
안내서 5개 작성하였습니다
Cal Poly, Team 10-7, Banghart Winter 2017 Cal Poly, Team 10-7, Banghart Winter 2017 회원
CPSU-BANGHART-W17S10G7
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 3
전체 시간: 473
