주요 콘텐츠로 건너뛰기
Panasonic Lumix DMC-FH20 Memory Card Replacement
  1. Panasonic Lumix DMC-FH20 Memory Card Replacement, Memory Card: 1 단계, 이미지 1/3 Panasonic Lumix DMC-FH20 Memory Card Replacement, Memory Card: 1 단계, 이미지 2/3 Panasonic Lumix DMC-FH20 Memory Card Replacement, Memory Card: 1 단계, 이미지 3/3
    • On the bottom of the camera, move the gray switch that has the words "open" and "lock" above it to the open position. The case will open.
  2. Panasonic Lumix DMC-FH20 Memory Card Replacement: 2 단계, 이미지 1/1
    • Once the case is open, you will see your memory card in the marked slot. Push the card down until you hear a small click. The card will then pop out and you will be able to remove it.
결론
Arianna Boushell
회원 가입일: 01/24/17
626 평판
안내서 5개 작성하였습니다
Cal Poly, Team 10-7, Banghart Winter 2017 Cal Poly, Team 10-7, Banghart Winter 2017 회원
CPSU-BANGHART-W17S10G7
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 16
전체 시간: 311
