주요 콘텐츠로 건너뛰기
Panasonic Lumix DMC-FH25 LCD Screen Replacement
필요한 것
  1. Panasonic Lumix DMC-FH25 LCD Screen Replacement, Back Case: 1 단계, 이미지 1/3 Panasonic Lumix DMC-FH25 LCD Screen Replacement, Back Case: 1 단계, 이미지 2/3 Panasonic Lumix DMC-FH25 LCD Screen Replacement, Back Case: 1 단계, 이미지 3/3
    • Remove 5 screws attached to the back case using a 00 Phillips head screwdriver.
  2. Panasonic Lumix DMC-FH25 LCD Screen Replacement: 2 단계, 이미지 1/1
    • Using your hands and a pry tool, lever the back case off.
  3. Panasonic Lumix DMC-FH25 LCD Screen Replacement: 3 단계, 이미지 1/2 Panasonic Lumix DMC-FH25 LCD Screen Replacement: 3 단계, 이미지 2/2
    • Remove the back case.
  4. Panasonic Lumix DMC-FH25 LCD Screen Replacement, LCD Screen: 4 단계, 이미지 1/3 Panasonic Lumix DMC-FH25 LCD Screen Replacement, LCD Screen: 4 단계, 이미지 2/3 Panasonic Lumix DMC-FH25 LCD Screen Replacement, LCD Screen: 4 단계, 이미지 3/3
    • Using a 00 Phillips head screwdriver, remove a screw from the top right corner of the screen.
    • Lift the screen, being careful not to tear the ribbon cables on the right side.
  5. Panasonic Lumix DMC-FH25 LCD Screen Replacement: 5 단계, 이미지 1/2 Panasonic Lumix DMC-FH25 LCD Screen Replacement: 5 단계, 이미지 2/2
    • Access the ribbon cables by removing the green button receiver panel using a plastic opening tool. There is a white panel beneath. Carefully remove this using a plastic opening tool. The white panel may require some elbow grease to get it off, and the panel may make a snapping sound as it comes off.
  6. Panasonic Lumix DMC-FH25 LCD Screen Replacement: 6 단계, 이미지 1/2 Panasonic Lumix DMC-FH25 LCD Screen Replacement: 6 단계, 이미지 2/2
    • One of the ribbon cables will be housed behind the screen and the other will be under the panels. Gently pull each free from the housing and remove the screen.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Janice Weldon
회원 가입일: 03/07/17
612 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team S6-G6, Isaacson Spring 2017 UMass Dartmouth, Team S6-G6, Isaacson Spring 2017 회원
UMASSD-ISAACSON-S17S6G6
3 회원들
안내서 10개 작성하였습니다
댓글 한 개
it has been quite easy tank you for sharing your help serge jobin
Serge Jobin - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 15
전체 시간: 476
