주요 콘텐츠로 건너뛰기
Panasonic Lumix DMC-FX01 Flash Top Assembly Replacement
필요한 것
  1. Panasonic Lumix DMC-FX01 Flash Top Assembly Replacement, Battery: 1 단계, 이미지 1/1
    • Locate the memory card and battery card latch on the bottom of the camera.
    • Slide the latch to the open position.
  2. Panasonic Lumix DMC-FX01 Flash Top Assembly Replacement: 2 단계, 이미지 1/1
    • Open the battery latch, and slide the battery release lever to the right.
  3. Panasonic Lumix DMC-FX01 Flash Top Assembly Replacement: 3 단계, 이미지 1/1
    • Remove the battery from the camera.
  4. Panasonic Lumix DMC-FX01 Flash Top Assembly Replacement, Rear Casing: 4 단계, 이미지 1/1
    • Remove the three 4.6 mm screws on the bottom of the camera using a Phillips #00 screwdriver.
  5. Panasonic Lumix DMC-FX01 Flash Top Assembly Replacement: 5 단계, 이미지 1/1
    • Remove the single 3.2 mm screw on the left side of the camera using a Phillips #00 screwdriver.
  6. Panasonic Lumix DMC-FX01 Flash Top Assembly Replacement: 6 단계, 이미지 1/2 Panasonic Lumix DMC-FX01 Flash Top Assembly Replacement: 6 단계, 이미지 2/2
    • Remove the left side casing.
  7. Panasonic Lumix DMC-FX01 Flash Top Assembly Replacement: 7 단계, 이미지 1/1
    • Remove the two 3.2 mm screws on the right side of the camera using a Phillips #00 screwdriver.
  8. Panasonic Lumix DMC-FX01 Flash Top Assembly Replacement: 8 단계, 이미지 1/1
    • Remove the bottom right panel.
  9. Panasonic Lumix DMC-FX01 Flash Top Assembly Replacement: 9 단계, 이미지 1/2 Panasonic Lumix DMC-FX01 Flash Top Assembly Replacement: 9 단계, 이미지 2/2
    • Gently remove the back casing.
    • Start at the bottom and carefully pry towards the top to get this piece free.
  10. Panasonic Lumix DMC-FX01 Flash Top Assembly Replacement, Flash Top Assembly: 10 단계, 이미지 1/2 Panasonic Lumix DMC-FX01 Flash Top Assembly Replacement, Flash Top Assembly: 10 단계, 이미지 2/2
    • Carefully pry the Flash Top Assembly away from the top.
  11. Panasonic Lumix DMC-FX01 Flash Top Assembly Replacement: 11 단계, 이미지 1/2 Panasonic Lumix DMC-FX01 Flash Top Assembly Replacement: 11 단계, 이미지 2/2
    • Replace the Flash Top Assembly with a new one.
결론
Caleb Fink
회원 가입일: 10/11/10
191 평판
안내서 2개 작성하였습니다
Cal Poly, Team 9-22, Regan Fall 2010 Cal Poly, Team 9-22, Regan Fall 2010 회원
CPSU-REGAN-F10S9G22
4 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 17
전체 시간: 3,863
