이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Locate the memory card and battery card latch on the bottom of the camera.
Slide the latch to the open position.
Open the battery latch, and slide the battery release lever to the right.
Remove the three 4.6 mm screws on the bottom of the camera using a Phillips #00 screwdriver.
Remove the single 3.2 mm screw on the left side of the camera using a Phillips #00 screwdriver.
Remove the two 3.2 mm screws on the right side of the camera using a Phillips #00 screwdriver.
Gently remove the back casing.
Start at the bottom and carefully pry towards the top to get this piece free.
