주요 콘텐츠로 건너뛰기
Panasonic Lumix DMC-FX01 Lens Assembly Replacement
필요한 것
  1. Panasonic Lumix DMC-FX01 Lens Assembly Replacement, Battery: 1 단계, 이미지 1/1
    • Locate the memory card and battery card latch on the bottom of the camera.
    • Slide the latch to the open position.
  2. Panasonic Lumix DMC-FX01 Lens Assembly Replacement: 2 단계, 이미지 1/1
    • Open the battery latch, and slide the battery release lever to the right.
  3. Panasonic Lumix DMC-FX01 Lens Assembly Replacement: 3 단계, 이미지 1/1
    • Remove the battery from the camera.
  4. Panasonic Lumix DMC-FX01 Lens Assembly Replacement, Rear Casing: 4 단계, 이미지 1/1
    • Remove the three 4.6 mm screws on the bottom of the camera using a Phillips #00 screwdriver.
  5. Panasonic Lumix DMC-FX01 Lens Assembly Replacement: 5 단계, 이미지 1/1
    • Remove the single 3.2 mm screw on the left side of the camera using a Phillips #00 screwdriver.
  6. Panasonic Lumix DMC-FX01 Lens Assembly Replacement: 6 단계, 이미지 1/2 Panasonic Lumix DMC-FX01 Lens Assembly Replacement: 6 단계, 이미지 2/2
    • Remove the left side casing.
  7. Panasonic Lumix DMC-FX01 Lens Assembly Replacement: 7 단계, 이미지 1/1
    • Remove the two 3.2 mm screws on the right side of the camera using a Phillips #00 screwdriver.
  8. Panasonic Lumix DMC-FX01 Lens Assembly Replacement: 8 단계, 이미지 1/1
    • Remove the bottom right panel.
  9. Panasonic Lumix DMC-FX01 Lens Assembly Replacement: 9 단계, 이미지 1/2 Panasonic Lumix DMC-FX01 Lens Assembly Replacement: 9 단계, 이미지 2/2
    • Gently remove the back casing.
    • Start at the bottom and carefully pry towards the top to get this piece free.
  10. Panasonic Lumix DMC-FX01 Lens Assembly Replacement, LCD Screen: 10 단계, 이미지 1/1
    • Gently lift up the LCD screen.
    • Using a plastic prying tool, flip up the latch that holds the thin ribbon in place.
    • It should fall out on its own or with a gentle tug.
  11. Panasonic Lumix DMC-FX01 Lens Assembly Replacement: 11 단계, 이미지 1/1
    • Gently tug the thicker ribbon to remove it from its housing.
  12. Panasonic Lumix DMC-FX01 Lens Assembly Replacement, Front Casing: 12 단계, 이미지 1/2 Panasonic Lumix DMC-FX01 Lens Assembly Replacement, Front Casing: 12 단계, 이미지 2/2
    • Remove the two black 5.4 mm screws that hold in the front faceplate using a Phillips #00 screwdriver.
    • There may be a third screw the the right of the lens assembly.
  13. Panasonic Lumix DMC-FX01 Lens Assembly Replacement: 13 단계, 이미지 1/3 Panasonic Lumix DMC-FX01 Lens Assembly Replacement: 13 단계, 이미지 2/3 Panasonic Lumix DMC-FX01 Lens Assembly Replacement: 13 단계, 이미지 3/3
    • Carefully remove the upper assembly, which houses the buttons and the flash battery.
  14. Panasonic Lumix DMC-FX01 Lens Assembly Replacement: 14 단계, 이미지 1/1
    • Carefully remove the front casing after verifying that the thin plastic around the lens is not still attached.
  15. Panasonic Lumix DMC-FX01 Lens Assembly Replacement, Lens Assembly: 15 단계, 이미지 1/2 Panasonic Lumix DMC-FX01 Lens Assembly Replacement, Lens Assembly: 15 단계, 이미지 2/2
    • Remove the three black 5mm screws attached to the lens frame.
  16. Panasonic Lumix DMC-FX01 Lens Assembly Replacement: 16 단계, 이미지 1/1
    • Remove the lens frame.
  17. Panasonic Lumix DMC-FX01 Lens Assembly Replacement: 17 단계, 이미지 1/1
    • Lift out the circuit board as shown.
  18. Panasonic Lumix DMC-FX01 Lens Assembly Replacement: 18 단계, 이미지 1/2 Panasonic Lumix DMC-FX01 Lens Assembly Replacement: 18 단계, 이미지 2/2
    • Lift the two black latches that hold the connector ribbons in place.
    • Disconnect the two ribbons.
  19. Panasonic Lumix DMC-FX01 Lens Assembly Replacement: 19 단계, 이미지 1/1
    • Remove the lens assembly as shown.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Steven
회원 가입일: 10/11/10
108 평판
안내서 2개 작성하였습니다
Cal Poly, Team 9-22, Regan Fall 2010 Cal Poly, Team 9-22, Regan Fall 2010 회원
CPSU-REGAN-F10S9G22
4 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 16
전체 시간: 9,599
