이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
This guide will be useful for anyone who wants to replace a broken or damaged lens assembly.
필요한 것
Locate the memory card and battery card latch on the bottom of the camera.
Slide the latch to the open position.
Remove the three 4.6 mm screws on the bottom of the camera using a Phillips #00 screwdriver.
Gently lift up the LCD screen.
Using a plastic prying tool, flip up the latch that holds the thin ribbon in place.
It should fall out on its own or with a gentle tug.
Remove the two black 5.4 mm screws that hold in the front faceplate using a Phillips #00 screwdriver.
다른 5명이 해당 안내서를 완성하였습니다.
