주요 콘텐츠로 건너뛰기
Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement
필요한 것
  1. Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement, Battery: 1 단계, 이미지 1/1
    • Locate the memory card and battery card latch on the bottom of the camera.
    • Slide the latch to the open position.
  2. Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement: 2 단계, 이미지 1/1
    • Open the battery latch, and slide the battery release lever to the right.
  3. Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement: 3 단계, 이미지 1/1
    • Remove the battery from the camera.
  4. Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement, Rear Casing: 4 단계, 이미지 1/1
    • Remove the three 4.6 mm screws on the bottom of the camera using a Phillips #00 screwdriver.
  5. Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement: 5 단계, 이미지 1/1
    • Remove the single 3.2 mm screw on the left side of the camera using a Phillips #00 screwdriver.
  6. Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement: 6 단계, 이미지 1/2 Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement: 6 단계, 이미지 2/2
    • Remove the left side casing.
  7. Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement: 7 단계, 이미지 1/1
    • Remove the two 3.2 mm screws on the right side of the camera using a Phillips #00 screwdriver.
  8. Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement: 8 단계, 이미지 1/1
    • Remove the bottom right panel.
  9. Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement: 9 단계, 이미지 1/2 Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement: 9 단계, 이미지 2/2
    • Gently remove the back casing.
    • Start at the bottom and carefully pry towards the top to get this piece free.
  10. Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement, LCD Screen: 10 단계, 이미지 1/1
    • Gently lift up the LCD screen.
    • Using a plastic prying tool, flip up the latch that holds the thin ribbon in place.
    • It should fall out on its own or with a gentle tug.
  11. Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement: 11 단계, 이미지 1/1
    • Gently tug the thicker ribbon to remove it from its housing.
    Not sure i the author forgot to add this, but the black part of this connector is locking mechanism for the ribbon. Lifting it will help.
    Michal Andres - 답글
  12. Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement, On/ Off Button and Settings Button: 12 단계, 이미지 1/2 Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement, On/ Off Button and Settings Button: 12 단계, 이미지 2/2
    • Carefully remove the upper assembly, which houses the buttons and the flash battery.
  13. Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement: 13 단계, 이미지 1/1
    • Remove the two 3mm screws.
  14. Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement: 14 단계, 이미지 1/2 Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement: 14 단계, 이미지 2/2
    • Pry bars back gently as shown.
    • Fingers can be used but tool is shown for clarity.
  15. Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement: 15 단계, 이미지 1/2 Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement: 15 단계, 이미지 2/2
    • After, releasing all the components, gently remove the flash assembly from the casing.
  16. Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement: 16 단계, 이미지 1/1
    • Remove the 1.2 mm screw from the settings wheel.
  17. Panasonic Lumix DMC-FX01 On/ Off and Settings Button cover replacement: 17 단계, 이미지 1/1
    • Replace buttons.
    • Replace the "On/ Off" button with the prongs facing away from the flash.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Andrew
회원 가입일: 10/11/10
396 평판
안내서 4개 작성하였습니다
Cal Poly, Team 9-22, Regan Fall 2010 Cal Poly, Team 9-22, Regan Fall 2010 회원
CPSU-REGAN-F10S9G22
4 회원들
안내서 8개 작성하였습니다
댓글 한 개
Olá ! Sugiro ter cuidado com a carga do capacitor do flash, melhor descarrega-lo com auxílio de uma lâmpada ou resistor
para evitar um choque elétrico.
Ricardo Britto - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 9
전체 시간: 5,052
