소개
Directions are given as if you were holding the camera to take a picture.
도구
부품
지정된 부품이 없습니다.
Locate the memory card and battery card latch on the bottom of the camera.
Slide the latch to the open position.
Using a size #00 Phillips screwdriver, remove the three 4.58 mm screws on the bottom of the camera.
Use this screwdriver for all screws in the device.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
