주요 콘텐츠로 건너뛰기
Panasonic Lumix DMC-FX07 LCD Display Replacement
필요한 것
  1. Panasonic Lumix DMC-FX07 LCD Display Replacement, Battery: 1 단계, 이미지 1/1
    • Move the switch on the battery door to the Open position.
    • The door will automatically swing open after you let it go.
  2. Panasonic Lumix DMC-FX07 LCD Display Replacement: 2 단계, 이미지 1/2 Panasonic Lumix DMC-FX07 LCD Display Replacement: 2 단계, 이미지 2/2
    • Push the small gray tab on the top right corner to the left. The battery will pop out slightly.
    • Keep your finger clear of the battery when it pops out.
  3. Panasonic Lumix DMC-FX07 LCD Display Replacement, Memory Card: 3 단계, 이미지 1/1
    • Push the memory card in and let go.
    • The memory card will pop out slightly.
    • Pull out the memory card.
  4. Panasonic Lumix DMC-FX07 LCD Display Replacement, Back Cover: 4 단계, 이미지 1/2 Panasonic Lumix DMC-FX07 LCD Display Replacement, Back Cover: 4 단계, 이미지 2/2
    • Unscrew the small screws on the sides of the camera.
    • The screws on the left side(#00P, 4.7mm) are longer than the screw on the right side(#00P, 3.3mm).
  5. Panasonic Lumix DMC-FX07 LCD Display Replacement: 5 단계, 이미지 1/2 Panasonic Lumix DMC-FX07 LCD Display Replacement: 5 단계, 이미지 2/2
    • Unscrew the three small screws on the bottom(#00P, 3.3mm).
    • The bottom will fall off.
  6. Panasonic Lumix DMC-FX07 LCD Display Replacement: 6 단계, 이미지 1/3 Panasonic Lumix DMC-FX07 LCD Display Replacement: 6 단계, 이미지 2/3 Panasonic Lumix DMC-FX07 LCD Display Replacement: 6 단계, 이미지 3/3
    • Lift up the bottom back cover by prying the bottom edge with the spudger.
    • Gently lift up the back cover with your hand from the bottom to the top.
  7. Panasonic Lumix DMC-FX07 LCD Display Replacement: 7 단계, 이미지 1/3 Panasonic Lumix DMC-FX07 LCD Display Replacement: 7 단계, 이미지 2/3 Panasonic Lumix DMC-FX07 LCD Display Replacement: 7 단계, 이미지 3/3
    • Lift the tabs on the ZIF connectors.
    • The ribbon cables should easily come out of the ZIF connectors.
  8. Panasonic Lumix DMC-FX07 LCD Display Replacement, LCD Display: 8 단계, 이미지 1/3 Panasonic Lumix DMC-FX07 LCD Display Replacement, LCD Display: 8 단계, 이미지 2/3 Panasonic Lumix DMC-FX07 LCD Display Replacement, LCD Display: 8 단계, 이미지 3/3
    • Use the pointed end of the spudger to pry off the LCD screen from the back cover. Place the tip of the spudger in the small hole in the bracket on the LCD screen and lift it out.
결론
James Cruz
회원 가입일: 04/14/12
6 평판
안내서 1개 작성함
Cal Poly, Team 6-23, Amido Spring 2012 Cal Poly, Team 6-23, Amido Spring 2012 회원
CPSU-AMIDO-S12S6G23
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 8
전체 시간: 1,812
