주요 콘텐츠로 건너뛰기
Panasonic Lumix DMC-FX07 Top Cover Replacement
필요한 것
  1. Panasonic Lumix DMC-FX07 Top Cover Replacement, Battery: 1 단계, 이미지 1/1
    • Move the switch on the battery door to the Open position.
    • The door will automatically swing open after you let it go.
  2. Panasonic Lumix DMC-FX07 Top Cover Replacement: 2 단계, 이미지 1/2 Panasonic Lumix DMC-FX07 Top Cover Replacement: 2 단계, 이미지 2/2
    • Push the small gray tab on the top right corner to the left. The battery will pop out slightly.
    • Keep your finger clear of the battery when it pops out.
  3. Panasonic Lumix DMC-FX07 Top Cover Replacement, Memory Card: 3 단계, 이미지 1/1
    • Push the memory card in and let go.
    • The memory card will pop out slightly.
    • Pull out the memory card.
  4. Panasonic Lumix DMC-FX07 Top Cover Replacement, Back Cover: 4 단계, 이미지 1/2 Panasonic Lumix DMC-FX07 Top Cover Replacement, Back Cover: 4 단계, 이미지 2/2
    • Unscrew the small screws on the sides of the camera.
    • The screws on the left side(#00P, 4.7mm) are longer than the screw on the right side(#00P, 3.3mm).
  5. Panasonic Lumix DMC-FX07 Top Cover Replacement: 5 단계, 이미지 1/2 Panasonic Lumix DMC-FX07 Top Cover Replacement: 5 단계, 이미지 2/2
    • Unscrew the three small screws on the bottom(#00P, 3.3mm).
    • The bottom will fall off.
  6. Panasonic Lumix DMC-FX07 Top Cover Replacement: 6 단계, 이미지 1/3 Panasonic Lumix DMC-FX07 Top Cover Replacement: 6 단계, 이미지 2/3 Panasonic Lumix DMC-FX07 Top Cover Replacement: 6 단계, 이미지 3/3
    • Lift up the bottom back cover by prying the bottom edge with the spudger.
    • Gently lift up the back cover with your hand from the bottom to the top.
  7. Panasonic Lumix DMC-FX07 Top Cover Replacement: 7 단계, 이미지 1/3 Panasonic Lumix DMC-FX07 Top Cover Replacement: 7 단계, 이미지 2/3 Panasonic Lumix DMC-FX07 Top Cover Replacement: 7 단계, 이미지 3/3
    • Lift the tabs on the ZIF connectors.
    • The ribbon cables should easily come out of the ZIF connectors.
  8. Panasonic Lumix DMC-FX07 Top Cover Replacement, Top Cover: 8 단계, 이미지 1/2 Panasonic Lumix DMC-FX07 Top Cover Replacement, Top Cover: 8 단계, 이미지 2/2
    • Using the spudger, pry off the top cover by gliding the spudger along the entire edge between the top cover and the front cover.
    • Be careful not to damage the cylindrical capacitor on the circuit board under the top cover.
결론
Karissa
회원 가입일: 04/13/12
50 평판
안내서 8개 작성하였습니다
Cal Poly, Team 6-23, Amido Spring 2012 Cal Poly, Team 6-23, Amido Spring 2012 회원
CPSU-AMIDO-S12S6G23
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 762
