주요 콘텐츠로 건너뛰기
Panasonic Lumix DMC-FX37 Photoreceptor Replacement
필요한 것
  1. Panasonic Lumix DMC-FX37 Photoreceptor Replacement, Panasonic Lumix DMC-FX37 Disassembly: 1 단계, 이미지 1/2 Panasonic Lumix DMC-FX37 Photoreceptor Replacement, Panasonic Lumix DMC-FX37 Disassembly: 1 단계, 이미지 2/2
    • Remove both of the 3 mm screws on the bottom of the camera connected to the side panel.
  2. Panasonic Lumix DMC-FX37 Photoreceptor Replacement: 2 단계, 이미지 1/2 Panasonic Lumix DMC-FX37 Photoreceptor Replacement: 2 단계, 이미지 2/2
    • Remove the remaining 3 mm screw holding on the side panel and remove the panel entirely.
  3. Panasonic Lumix DMC-FX37 Photoreceptor Replacement: 3 단계, 이미지 1/2 Panasonic Lumix DMC-FX37 Photoreceptor Replacement: 3 단계, 이미지 2/2
    • On the opposite side of the camera, remove the two 3 mm screws.
    • Remove the bottom side panel and place it with its respective 3 mm screw.
  4. Panasonic Lumix DMC-FX37 Photoreceptor Replacement: 4 단계, 이미지 1/3 Panasonic Lumix DMC-FX37 Photoreceptor Replacement: 4 단계, 이미지 2/3 Panasonic Lumix DMC-FX37 Photoreceptor Replacement: 4 단계, 이미지 3/3
    • Remove the front panel (the panel around the lens casing) from the camera.
    • Remove the two ribbon cables connected to the back panel (the panel this the LCD screen) by lifting up on their respective tabs and gently pulling out the cord.
    • Caution: When removing the back panel, the two ribbon cables are relatively delicate and must both be disconnected before the panel can be entirely removed.
    • Remove the back panel from the camera.
  5. Panasonic Lumix DMC-FX37 Photoreceptor Replacement: 5 단계, 이미지 1/1
    • Remove the top control panel (connected to the flash battery) from the camera.
    • The top control panel is connected to the rest of the camera by a delicate multi-pin plug. Be careful as to not bend the pins!
  6. Panasonic Lumix DMC-FX37 Photoreceptor Replacement, Photoreceptor: 6 단계, 이미지 1/2 Panasonic Lumix DMC-FX37 Photoreceptor Replacement, Photoreceptor: 6 단계, 이미지 2/2
    • Locate and remove the silver 2mm screw on the protection panel.
    • Remove the three black 8mm screws that remain.
    • Be sure to remember which length of screw goes to which slot. Failing to do so could damage your device.
    • Proceed to remove the protection panel entirely.
  7. Panasonic Lumix DMC-FX37 Photoreceptor Replacement: 7 단계, 이미지 1/1
    • Insert the flat end of a plastic spudger underneath the motherboard and twist. This will disconnect the board from the device and allow it to be removed.
  8. Panasonic Lumix DMC-FX37 Photoreceptor Replacement: 8 단계, 이미지 1/1
    • Use the pointed end of the spudger to lift the black tabs holding the ribbon cable connected to the photoreceptor in place.
    • Before pulling the cable free, be sure to complete the next step (removing the screws) as the ribbon cables are delicate and must be handled with care.
  9. Panasonic Lumix DMC-FX37 Photoreceptor Replacement: 9 단계, 이미지 1/2 Panasonic Lumix DMC-FX37 Photoreceptor Replacement: 9 단계, 이미지 2/2
    • Remove the three 3mm screws holding the photoreceptor in place.
    • Carefully lift the photoreceptor, disconnecting the ribbon cable and remove the photoreceptor from the device.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Zhentao
회원 가입일: 01/30/18
247 평판
안내서 2개 작성하였습니다
Baylor, Team S2-G3, Johnson Spring 2018 Baylor, Team S2-G3, Johnson Spring 2018 회원
BU-JOHNSON-S18S2G3
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 265
