주요 콘텐츠로 건너뛰기
Panasonic Lumix DMC-FX9 Selector Buttons Replacement
필요한 것
  1. Panasonic Lumix DMC-FX9 Selector Buttons Replacement, Selector Buttons: 1 단계, 이미지 1/1
    • Make sure the power is off by switching the power switch to the left.
  2. Panasonic Lumix DMC-FX9 Selector Buttons Replacement: 2 단계, 이미지 1/2 Panasonic Lumix DMC-FX9 Selector Buttons Replacement: 2 단계, 이미지 2/2
    • Use a Phillips #00 screwdriver to remove the screws on the left side of the camera.
  3. Panasonic Lumix DMC-FX9 Selector Buttons Replacement: 3 단계, 이미지 1/1
    • Remove the screws on the right side of the camera by using the Philips #00 screwdriver.
  4. Panasonic Lumix DMC-FX9 Selector Buttons Replacement: 4 단계, 이미지 1/2 Panasonic Lumix DMC-FX9 Selector Buttons Replacement: 4 단계, 이미지 2/2
    • Remove the screws on the bottom side of the camera using the Philips #00 Screwdriver.
    • Separate the covers by gently applying force upwards, carefully placing the opening tool between the two covers.
  5. Panasonic Lumix DMC-FX9 Selector Buttons Replacement: 5 단계, 이미지 1/2 Panasonic Lumix DMC-FX9 Selector Buttons Replacement: 5 단계, 이미지 2/2
    • Lift the ZIF tabs up with the opening tool and carefully remove the digitizer ribbon cables.
    • Remove the LCD Screen from the glass frame carefully with the opening tool.
  6. Panasonic Lumix DMC-FX9 Selector Buttons Replacement: 6 단계, 이미지 1/2 Panasonic Lumix DMC-FX9 Selector Buttons Replacement: 6 단계, 이미지 2/2
    • Push on the back panel buttons on the front side to remove the buttons.
    • Be cautious of the adhesive holding the button panels to the cover. Apply extra force if necessary.
결론
Kriselle Tubongbanua
회원 가입일: 02/21/18
133 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 6
30일 전: 13
전체 시간: 265
