주요 콘텐츠로 건너뛰기
Panasonic Lumix DMC-FZ1000 Motherboard Replacement
필요한 것
  1. Panasonic Lumix DMC-FZ1000 Motherboard Replacement, Battery: 1 단계, 이미지 1/3 Panasonic Lumix DMC-FZ1000 Motherboard Replacement, Battery: 1 단계, 이미지 2/3 Panasonic Lumix DMC-FZ1000 Motherboard Replacement, Battery: 1 단계, 이미지 3/3
    • Slide the switch on the bottom of your camera from the right (LOCK) to the left (OPEN).
    • The battery door will swing open.
  2. Panasonic Lumix DMC-FZ1000 Motherboard Replacement: 2 단계, 이미지 1/2 Panasonic Lumix DMC-FZ1000 Motherboard Replacement: 2 단계, 이미지 2/2
    • Pull down on the lever that holds the battery.
    • The battery will pop out of its casing.
  3. Panasonic Lumix DMC-FZ1000 Motherboard Replacement: 3 단계, 이미지 1/1
    • Pull out the battery.
  4. Panasonic Lumix DMC-FZ1000 Motherboard Replacement, Motherboard: 4 단계, 이미지 1/3 Panasonic Lumix DMC-FZ1000 Motherboard Replacement, Motherboard: 4 단계, 이미지 2/3 Panasonic Lumix DMC-FZ1000 Motherboard Replacement, Motherboard: 4 단계, 이미지 3/3
    • Push in on the SD card inside the battery housing.
    • The SD card will pop out.
    • Pull out the SD card.
    • Close the battery housing door.
  5. Panasonic Lumix DMC-FZ1000 Motherboard Replacement: 5 단계, 이미지 1/3 Panasonic Lumix DMC-FZ1000 Motherboard Replacement: 5 단계, 이미지 2/3 Panasonic Lumix DMC-FZ1000 Motherboard Replacement: 5 단계, 이미지 3/3
    • Remove the two 5.2 mm Phillips #00 screws that are 1) below the label and 2) above the tripod mount hole on the bottom of the camera.
    • You may ignore the screw below the tripod mount hole.
    • Remove the two 5.5 mm Phillips #00 screws on the side of the camera with the MIC jack.
    • Remove the two 7.0 mm Phillips #00 screws that are 1) above and 2) below the HDMI panel.
    • You may ignore the screw that goes through the leather material to the right of the HDMI panel.
    • There are two screws that hold the eye piece on to the main housing, just underneath. Remove these. Once these have been removed, gently pull and remove the eye piece and remove the now accessible top two screws.
  6. Panasonic Lumix DMC-FZ1000 Motherboard Replacement: 7 단계, 이미지 1/3 Panasonic Lumix DMC-FZ1000 Motherboard Replacement: 7 단계, 이미지 2/3 Panasonic Lumix DMC-FZ1000 Motherboard Replacement: 7 단계, 이미지 3/3
    • Do not yank off the back plate. If you do, you will tear the electronic ribbons attached to the inside of the camera and the back plate.
    • Gently lift up the back plate, being careful not to damage any ribbons.
    • Do not yank out the electronic ribbons attached to the motherboard and the back plate, or you may damage them. To properly detach these ZIF connector ribbons, see this technique on disconnecting ZIF connectors.
    • Pull to disconnect from the motherboard the two ZIF connector ribbons attached to the back plate.
    • Set aside the back plate.
  7. Panasonic Lumix DMC-FZ1000 Motherboard Replacement: 8 단계, 이미지 1/1
    • Do not yank out the electronic ribbons attached to the motherboard, or you may damage them. To properly detach these ZIF connector ribbons, see this technique on disconnecting ZIF connectors.
    • Pull to disconnect from the motherboard the seven ZIF connector ribbons.
  8. Panasonic Lumix DMC-FZ1000 Motherboard Replacement: 9 단계, 이미지 1/1
    • Remove the four 5.2 mm Phillips #00 screws at the corners of the motherboard.
  9. Panasonic Lumix DMC-FZ1000 Motherboard Replacement: 10 단계, 이미지 1/3 Panasonic Lumix DMC-FZ1000 Motherboard Replacement: 10 단계, 이미지 2/3 Panasonic Lumix DMC-FZ1000 Motherboard Replacement: 10 단계, 이미지 3/3
    • Firmly grasp the left side of the motherboard.
    • Pull out the motherboard.
    • If you find it difficult to remove the motherboard, pull it away from the HDMI panel while pulling it out.
결론
다른 7명이 해당 안내서를 완성하였습니다.
Robseth Taas
회원 가입일: 01/07/16
1,673 평판
안내서 5개 작성하였습니다
Cal Poly, Team 70-5, Forte Winter 2016 Cal Poly, Team 70-5, Forte Winter 2016 회원
CPSU-FORTE-W16S70G5
4 회원들
안내서 11개 작성하였습니다
3 댓글
Where do you buy a motherboard for this camera?
Pekka Liemola - 답글
This article is useless, since the motherboards are not available anywhere.
Pete Schliebner - 답글
Actually, Panasonic does have the part for sale. <https://panasonic.encompass.com/item/102...>
Jeffry Long - 답글
댓글 쓰기
조회 통계:
24 시간 전: 6
7일 전: 21
30일 전: 77
전체 시간: 6,235
