주요 콘텐츠로 건너뛰기
Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement
필요한 것
  1. Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement, Diopter Adjustment Dial: 1 단계, 이미지 1/3 Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement, Diopter Adjustment Dial: 1 단계, 이미지 2/3 Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement, Diopter Adjustment Dial: 1 단계, 이미지 3/3
    • Remove the four 4.6mm J000 Phillips screws from the sides and two 3.2mm J000 Phillips screws along the bottom.
  2. Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement: 2 단계, 이미지 1/3 Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement: 2 단계, 이미지 2/3 Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement: 2 단계, 이미지 3/3
    • Remove the two 3.2mm J000 Phillips screws located on the bottom edge of the viewfinder cover.
    • Carefully remove the viewfinder cover.
    • Remove the two 4.4mm J000 Phillips screws located near the top edge of the viewfinder.
  3. Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement: 3 단계, 이미지 1/3 Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement: 3 단계, 이미지 2/3 Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement: 3 단계, 이미지 3/3
    • Slide the Wide Plastic Opening Tool upwards along the underside of the rear casing.
    • Be careful not to disconnect the filament connections. Reinserting them can be difficult.
    • Slowly lower the casing into the position shown.
  4. Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement: 4 단계, 이미지 1/2 Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement: 4 단계, 이미지 2/2
    • Use the Screwdriver J000 Phillips Head to remove the screw located at the lower-left corner of the face of the viewfinder glass.
    • Carefully lift the L-shaped clicker underneath the previously removed screw.
  5. Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement: 5 단계, 이미지 1/2 Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement: 5 단계, 이미지 2/2
    • Slide the faulty diopter adjustment dial off the rod.
    • Replace the diopter dial with a 1-cm wheel.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Gabriel Gonzalez Jr
회원 가입일: 02/14/17
325 평판
안내서 3개 작성하였습니다
USF Tampa, Team 1-3, Kass Spring 2017 USF Tampa, Team 1-3, Kass Spring 2017 회원
USFT-KASS-S17S1G3
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 13
전체 시간: 1,025
