주요 콘텐츠로 건너뛰기
Panasonic Lumix DMC-G5 LCD Replacement
필요한 것
  1. Panasonic Lumix DMC-G5 LCD Replacement, LCD: 1 단계, 이미지 1/2 Panasonic Lumix DMC-G5 LCD Replacement, LCD: 1 단계, 이미지 2/2
    • Use J0 screwdriver to remove the two 3.2 mm screws from the outside of the assembly.
    • Use the J0 screwsdriver to remove the two 5.6 mm screws from the inside of the face near the swivel.
    • Rotate the face to more easily gain access to the screws.
  2. Panasonic Lumix DMC-G5 LCD Replacement: 2 단계, 이미지 1/2 Panasonic Lumix DMC-G5 LCD Replacement: 2 단계, 이미지 2/2
    • Slide the wide plastic opening tool underneath the crack of the side of the face and separate the components.
  3. Panasonic Lumix DMC-G5 LCD Replacement: 3 단계, 이미지 1/1
    • Carefully remove the filament connections from the LCD backing by lifting the black lever up first on the connector, then pulling gently outward from the LCD backing with your fingers.
    • Replace the filament connections into the backing of the new LCD face to complete replacement..
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Gabriel Gonzalez Jr
회원 가입일: 02/14/17
325 평판
안내서 3개 작성하였습니다
USF Tampa, Team 1-3, Kass Spring 2017 USF Tampa, Team 1-3, Kass Spring 2017 회원
USFT-KASS-S17S1G3
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 28
전체 시간: 1,972
