주요 콘텐츠로 건너뛰기
Panasonic Lumix DMC-G5 Lens Connection Assembly Replacement
필요한 것
  1. Panasonic Lumix DMC-G5 Lens Connection Assembly Replacement, Lens Connection Assembly: 1 단계, 이미지 1/1
    • Remove the four 5.4 mm J000 screws from the front lens mount.
  2. Panasonic Lumix DMC-G5 Lens Connection Assembly Replacement: 2 단계, 이미지 1/2 Panasonic Lumix DMC-G5 Lens Connection Assembly Replacement: 2 단계, 이미지 2/2
    • Use your hands or the thin plastic opening tool to remove the external housing ring as well as the smaller internal ring underneath.
    • Keep in mind that the red dot should be on the left side of the face. A small hole on the right side keeps the external ring centered on the lens release button. A similar hole on the left side keeps the internal ring centered underneath.
    • The three short depressed sections of the internal ring should be facing into the camera during reassembly.
  3. Panasonic Lumix DMC-G5 Lens Connection Assembly Replacement: 3 단계, 이미지 1/2 Panasonic Lumix DMC-G5 Lens Connection Assembly Replacement: 3 단계, 이미지 2/2
    • Use the Thin Plastic Opening Tool to release the black connection ring.
    • Insert the tool underneath the right side of the black ring to improve leverage.
    • Let the ring fall forward to reveal its underside.
    • Take care not to disconnect the filament connections from the camera as they can be very difficult to reconnect.
  4. Panasonic Lumix DMC-G5 Lens Connection Assembly Replacement: 4 단계, 이미지 1/2 Panasonic Lumix DMC-G5 Lens Connection Assembly Replacement: 4 단계, 이미지 2/2
    • Remove the two 2.7mm J000 phillips screws from the mount ring which connect to the ribbon of filament connections.
    • There are many small golden-colored springs and rivets within the black ring connector. They will fall out if held upside down. When reassembling, they should be in contact with the gold plating of the filament connection.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Gabriel Gonzalez Jr
회원 가입일: 02/14/17
325 평판
안내서 3개 작성하였습니다
USF Tampa, Team 1-3, Kass Spring 2017 USF Tampa, Team 1-3, Kass Spring 2017 회원
USFT-KASS-S17S1G3
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 15
전체 시간: 1,151
