주요 콘텐츠로 건너뛰기
Panasonic Lumix DMC-G5 Motherboard Replacement
필요한 것
  1. Panasonic Lumix DMC-G5 Motherboard Replacement, Back Panel: 1 단계, 이미지 1/1
    • Remove four JIS #000 screws from the bottom part of the camera.
  2. Panasonic Lumix DMC-G5 Motherboard Replacement: 2 단계, 이미지 1/2 Panasonic Lumix DMC-G5 Motherboard Replacement: 2 단계, 이미지 2/2
    • Remove two JIS #000 screws from both sides of the camera.
  3. Panasonic Lumix DMC-G5 Motherboard Replacement: 3 단계, 이미지 1/1
    • Remove two JIS #000 screws under the viewfinder.
  4. Panasonic Lumix DMC-G5 Motherboard Replacement: 4 단계, 이미지 1/2 Panasonic Lumix DMC-G5 Motherboard Replacement: 4 단계, 이미지 2/2
    • Remove the viewfinder lid.
    • Then, remove the two JIS #000 screws on the viewfinder.
  5. Panasonic Lumix DMC-G5 Motherboard Replacement: 5 단계, 이미지 1/3 Panasonic Lumix DMC-G5 Motherboard Replacement: 5 단계, 이미지 2/3 Panasonic Lumix DMC-G5 Motherboard Replacement: 5 단계, 이미지 3/3
    • Gently remove the back panel from the camera.
    • Unclip the ribbon cable from the motherboard using Wide Plastic Opening Tools and pull the cable gently.
  6. Panasonic Lumix DMC-G5 Motherboard Replacement, Motherboard: 6 단계, 이미지 1/1
    • Remove the JIS #000 screws on the motherboard.
  7. Panasonic Lumix DMC-G5 Motherboard Replacement: 7 단계, 이미지 1/2 Panasonic Lumix DMC-G5 Motherboard Replacement: 7 단계, 이미지 2/2
    • Unclip the ribbon cable using the Wide Plastic Opening Tool on the motherboard.
    • Gently pull out the cable.
  8. Panasonic Lumix DMC-G5 Motherboard Replacement: 8 단계, 이미지 1/1
    • Pull out the motherboard from the camera.
결론
Khairul Samsudin
회원 가입일: 05/22/19
412 평판
안내서 4개 작성하였습니다
IUPUI, Team S1-G4, Harley Summer 2019 IUPUI, Team S1-G4, Harley Summer 2019 회원
IUPUI-HARLEY-SU19S1G4
3 회원들
안내서 8개 작성하였습니다
댓글 한 개
Dear Khairul Samsudin - this is great, thank you so much.
Can I ask about another classic repair for the Lumix G5?
As with many lumix cameras, the rear thumbwheel on the Lumix G5 is a weak point and frequently fails - usually the “push in” movement that should change functions failes in the “pushed in” position.
Plese can you see if you can create a “fix” for this? It classically fails at about year 2-3, when the camera is out of warranty and the repairs cost from Panasonic is more than a secondhand G5 on eBay will cost!
Best wishes - Paul in the UK
Paul C - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 23
전체 시간: 1,383
