소개
This guide requires the use of a screw driver and close attention to which screws need to be removed. While following these steps, be careful not to rip out the blue and yellow ZIF ribbons that attach the back cover to the camera.
도구
부품
지정된 부품이 없습니다.
On the bottom of the camera, use your finger to push the lock button to the open position which will cause the hinged door to swing open.
Using a Phillips #00 screwdriver, remove six 2.69mm, silver screws located on the two short sides of the camera and the bottom side.
거의 끝나갑니다!
결론
