소개
This guide requires the use of a screw driver and close attention to which screws need to be removed.
On the bottom of the camera, use your finger to push the lock button to the open position which will cause the hinged door to swing open.
Using a Philips #00 screwdriver, remove six 2.69 mm screws located on the two short sides and on the bottom of the camera.
거의 끝나갑니다!
결론
