주요 콘텐츠로 건너뛰기
Panasonic Lumix DMC-GX85 Display Screen Replacement
필요한 것
  1. Panasonic Lumix DMC-GX85 Display Screen Replacement, Display Screen: 1 단계, 이미지 1/1
    • Turn the camera so that the shutter side faces the ground and the lens faces you.
  2. Panasonic Lumix DMC-GX85 Display Screen Replacement: 2 단계, 이미지 1/3 Panasonic Lumix DMC-GX85 Display Screen Replacement: 2 단계, 이미지 2/3 Panasonic Lumix DMC-GX85 Display Screen Replacement: 2 단계, 이미지 3/3
    • Remove the two 2mm Phillips #0 screws on the bottom of the screen.
  3. Panasonic Lumix DMC-GX85 Display Screen Replacement: 3 단계, 이미지 1/2 Panasonic Lumix DMC-GX85 Display Screen Replacement: 3 단계, 이미지 2/2
    • Swivel the screen away from the camera body so it is facing the ground.
  4. Panasonic Lumix DMC-GX85 Display Screen Replacement: 4 단계, 이미지 1/3 Panasonic Lumix DMC-GX85 Display Screen Replacement: 4 단계, 이미지 2/3 Panasonic Lumix DMC-GX85 Display Screen Replacement: 4 단계, 이미지 3/3
    • Remove the two 6.0mm Phillips #0 screws on the back of the screen.
  5. Panasonic Lumix DMC-GX85 Display Screen Replacement: 5 단계, 이미지 1/3 Panasonic Lumix DMC-GX85 Display Screen Replacement: 5 단계, 이미지 2/3 Panasonic Lumix DMC-GX85 Display Screen Replacement: 5 단계, 이미지 3/3
    • Orient the camera so the lens is facing the ground.
    • Using the gap created behind the screen at the bottom, stick the iFixit opening tool inside the gap and gently open the gap.
    • Work the tool evenly around the back of the display to evenly separate the two pieces. Once the back cover is separated enough, remove it by hand.
  6. Panasonic Lumix DMC-GX85 Display Screen Replacement: 6 단계, 이미지 1/3 Panasonic Lumix DMC-GX85 Display Screen Replacement: 6 단계, 이미지 2/3 Panasonic Lumix DMC-GX85 Display Screen Replacement: 6 단계, 이미지 3/3
    • Be sure to use extreme caution when handling the ribbon cable to ensure the wiring within it stays intact.
    • Place the camera so that the lens is facing the ground.
    • Using the iFixit opening tool, pry the black connector open and remove the ribbon.
  7. Panasonic Lumix DMC-GX85 Display Screen Replacement: 7 단계, 이미지 1/1
    • Gently remove the screen from the camera body.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Hae Bom
회원 가입일: 09/17/19
560 평판
안내서 3개 작성하였습니다
댓글 3개
Thank you very much!
jptrinkster - 답글
Hi ! Thanks for the tutorial, any idea if this would be the same repair with a DC-GX9 ? The screen size seems to match
Clem - 답글
Thanks for the guide. From step 7, how do I further dismantle the screen. I bought a replacement screen, but its in a simpler form
Kamil Zidane - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 14
30일 전: 84
전체 시간: 3,938
