소개
Over time, the tension in the spring of your Panasonic Lumix DMC-GX85’s flash can diminish causing unwanted lighting issues when using your device. A simple solution to prolong the quality of your camera is to replace the spring in the flash once every thousand hours of use.
필요한 것
Orient the camera so that the display screen is facing you.
Press the flash button to reveal the camera's pop-up flash.
다른 2명이 해당 안내서를 완성하였습니다.
댓글 2개
Hello,
sorry to bother you, but i would like to ask you for an expert opinion - help.
I had to replace the flash spring on my device / camera. After installation, the flash works as it should, but when closing the flash and turning off the camera, the camera tells me to insert the flash (then it turns off classically). I noticed that there was a small magnet in the flash, which I assume a function to confirm the closing of the flash door.
I would just like to ask where exactly to place it? I've already tried all the places where it should be stored, but I'm still groping ... (see photo)
I will be very grateful for your advice.
Regards and good health, Martin
Czech Republic
can't seem to find where to get a replacement spring. can you help?
